Question about Canon PIXMA MP510 All-In-One InkJet Printer
''The following ink tank cannot be recognised'' MP510
The above is the error message. All inks are full and when I load they all light up as normal, however, when I then close lid, the message appears and the light has gone out.
I assume that it is easy to fix but how?
  • 2 more comments
  • Anonymous Nov 25, 2008
    after refiling cartridges on my MP510 one colour is still flashing
  • noore Apr 10, 2009
    Can not recognise ink tank. When I push tank in side, all lit up, but as soon as close the lid, it gives CMY not recognise. code U043.
  • raydave Apr 12, 2009
    Error message- "does not recognise ink tank". After reinserting the inktank it lights up red. But after closing the cover it comes back with the light off and the same error message.
  • Anonymous May 19, 2009
    I have original canon cartridges and after the 6 counts reset, still the same problem, "does not recognize" also a new cartridge gives the same error message
    Guru:
  • 859 Answers
Try this to turn off ink level checking.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
This will disable ink level checking. The ink level checking doesn't always work well after a while and you can use this to refill your ink tanks as well.
Refilling ink tanks comes with its own risks and is known to not work well at higher altitudes above sea level. The closer to 4,000ft, roughly, the more likely the ink tank is to leak. And, these tanks can only be refilled about three times before the holes in the bubble jet corrode and are out of round. This will show as text that is not crisp to the eye in appearance.
Regards,
Worldvet
Posted on Nov 11, 2008
  • Glenn Rogers
    Glenn Rogers Nov 18, 2008
    Did you resolve this problem or do you want to try another root?
  • hellraiser_j Jan 20, 2011
    i made resets for how many times on my canon 228 but after the last reset i made it does not recognized any of my cartridges regardless if it is newly bought? can u help me get this over?i highly appreciate your answer.thanks!!!
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Some ink tanks can't be recognised
please remove the cartridge and printer of after smoth cloths is in water and clean the cartridge cerkit and opp sid in cartridge ( onder of printer) please clean and after 10minuts will you chaked.
Jul 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
Cyan ink tank not recognised
I phoned Canon Tech Support Center this morning. They had me replace the ink tank giving me the U150 error code and are sending me a replacement tank. HOPEFULLY this will solve the problem.
Oct 27, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon iP4300 - ink tanks not recognised
Buy HP instead Canon :) This is the only solution..
Oct 05, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
1,377 people viewed this question
old marine
old marine
