Question about Fisher and Paykel Refrigerators
Fridge and freezer not staying cold and temperture rising also thermother flashing red at back of fridge
    Genius:
  • 1,122 Answers
Is there frost building up in back of freezer?
Posted on Nov 11, 2008
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
Freezer is ok but fridge won't stay cold. I also
tube between freezer and fridge to bottom gets clogged . usually behind a plastic strip on back wall. defrost and blow it out and it will get happy
Oct 20, 2009 | Refrigerators
Fridge won't stay cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Refrigerators
MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY TEMPERATURE ON THE FRIDGE IS FLASHING. THE MODEL NO. RS21DCNS THE FRIDGE IS NOT COLD ENONUGH AND I PUT THE TEMPRATURE ON HIGH AND IMMEDIANTLY IT WENT BACK DOWN....
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Jul 07, 2009 | Samsung Refrigerators
Electrolux frost free fridge freezer
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
Zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
77 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
