Sharp AR 407
Thanks My Friend,
i changed the developer and toner new.
but Whats code for reset the counter
  • Anonymous Nov 20, 2008
    I keep getting the message " Drum Life Reached" , but this is the Second
    NEW drum.
    Need help
    Thx twslyme
  • 2,794 Answers
Try this procedure:
http://olsonbros.com/sharp/support/ar16x_devinstall.html
Posted on Nov 11, 2008
My copier needs developer. i would like to know how to install developer and the code to calibrate the developer
On the AR-407:
To remove the developer/toner cartridge, there is a green lever inside the front door/cover. Pull it down like you are going to refill the toner, pull it out, and there is a release lever on the right side bottom, between the cartridge and the copier. This will release the cartridge and allow you to slide the whole mechanism out.
There are 4 screws that hold the toner box onto the developer. (NOT THE TOP MOST COVER SCREWS) 2 on the left side (with the toner hopper on your right), and 1 screw on the right top, and 1 screw on the right side by the handle you use to pull the cartridge out of the machine. Make sure you also disconnect the electrical connector that attaches to the hopper motor.
Be careful not to spill the toner or developer as you are seperating the two.
The developer unit is the bottom unit.
Dump out old developer (make sure you get all of it by turning the gear on the back side). If you don't have a toner/developer vacuum, then just get as much out as you can. A normal vacuum motor will eat itself in a very short time trying to vacuum up toner or developer, because the particles are too small for a regular filter.
When you get all the developer out, then carefully open the new developer packet, and evenly pour it in. Put it back together the same way you took it apart.
Reset Developer counter : Simulation 24-5
Hope this helps!!
Ryan K
Nov 02, 2010 | Sharp AR-407 Copier
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR 407
You will need to get some developer.  Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum.  Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter.  If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
Nov 11, 2008 | Office Equipment & Supplies
Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Jun 05, 2008 | Office Equipment & Supplies
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
152 people viewed this question
jasbo
jasbo
