Question about Memorex MP3122 Cassette/CD Boombox
Boombox The lid to my cd player will not close, du to a broken piece inside the cd player. Can I replace that piece.
  • xenab43 Nov 13, 2007
    I also have a Memorex MP3122 CD Boombox whereas the lid will not close. I really like the player, the sound is good, the cd player works but I have to hold the lid down with a (slightly) heavy object. The spring inside must not be working - the piece that grabs the top of the cd door has no tension on it.
Why doesn't lid stay closed?
The flimsy lid latch is defective or broken. You may have to improvise a repair to get it working again.
Mar 05, 2016 | Memorex MP3126 Cassette/CD Boombox
Model ftw3011kwo washing machine won't work after breaking locking lid piece
Thank you for your inquiry, David Castro!
I understand that your Frigidaire washer is not working after the lid piece became broken. If the lid piece is not latching properly inside of the door latch then your washer is not registering the door is closed and will not start. You may need to have that piece replaced I would recommend having any electrical component replaced by an authorized technician. I hope this is helpful. -Matt
Dec 14, 2014 | Frigidaire Washing Machines
RCA RP-7979 - what is the small black piece that the CD snaps onto inside CD player?
You probably are missing the hub. Your CDs won't play without it
Jun 25, 2013 | RCA RP-9316 Boombox
LID WON'T CLOSE ON CD PLAYER
The CD loading mechanism have the fault. Check its loading belt. If loading belt has broken, the try wont close of open. If loading belt is OK. replace the loading motor.
Aug 12, 2012 | GPX Audio Players & Recorders
Not work CD Player
HelloCheck the CD spins inside it, when we close the lid. if not, check the lid. There is a small swelling like formation at its edge that will get into the CD player, when we close it. This will hit on a micro switch inside the set, which in turn send a CD in signal to its system control IC. If this signal does not reach the main system control IC, it won't sense that CD is in. If this switching process is OK, when you close the CD lid, make sure that the CD mechanism has the trouble, and need service. OK.
Dec 18, 2011 | Aiwa CSD-TD49 Cassette/CD Boombox
Sony cfd-z110 cd seems to not spin/play when door/lid is closed but will play when lid is open and lid switch is depressed, is there any thing (maintence) that needs done on that round piece (that is...
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Dec 31, 2010 | Sony ZS-S2IP Radio Boombox
The lock on the right side seems to have broken, and dryer lid is stuck closed. The washer will not continue washing because this piece is not working properly.
it has probably got a interlock that is brocken inside hence machine will not work try opening the lid and replace the lock unit ...good luck kev
Nov 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Mintek 1750 won't play dvd's when I install dvd and close lid the open icon at top left corner shows and it will not play
It sees the lid as being open. The lid has a projection from it that pushes a door switch when it is closed. Is this piece broken off ? or the switch is defective....
Mar 29, 2010 | Mintek MDP-1750 DVD Player
I load the CD put I don't hear it spinning at all
No it isn't, because your switch isn't tripping when you close the DVD. Try holding the lid down with your hand and listen for spin. If your DVD starts spinning you will need to locate the plastic pin protruding from your lid and extend it with superglue and a piece of cardboard. This will make up for the warp in your lid, and allow the switch to close.
Mar 09, 2010 | Mintek MDP-1810 Portable DVD Player
Memorex MP3122 Cassette/CD Boombox Logo
126 people viewed this question
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Tbone41
Level 1 Expert
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
