Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Can't Send Faxes
I can receive faxes and phone calls but cannot send faxes or make out going calls -
  • krissppie2 Jan 23, 2009
    The macine worked fine at first, then started to sporadically send faxes and now won't fax at all. I cna receieve faxes, receieve calls and call out but cannot send faxes. Have tried all the suggested "solutions".
    Problem Solver:
  • 4 Answers
You please check the mode of your telephone i.e Pulse or Tone mode This may solve your problem
Posted on Nov 14, 2008
  • 81 Answers
It could be the modem. Disconnect the machine from the phone line and plug a phone directly into the line. If that works properly, the problem is most likely the modem on the lexmark. If this is the case, you should find someone locally to assist you with the repair.
Posted on Nov 12, 2008
    Scholar:
  • 147 Answers
1. You might have to dial 9 first, if you are connected to an office pbx phone system.
2. If there are two phone jacks on the back of the unit, try plugging the line into the other one.
    Sergeant:
    Champion:
  • 283 Answers
1. turn off the machine
2. detached the phone line
3. reconnect and swithed on
if doenst wok you need to go to service center coz its a technical problem.
THANK you...plz dont rate me if you are not satisfied,,tnx again
    Novelist:
    Scholar:
  • 125 Answers
Can't really help you is you dont advise the printer model. Only thing I can ask is if the phone lines are connected or not as well as the power supply cable?
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Able to send and receive faxes. some numbers
It does not sound as if there is a problem with your machine. The receiving parties may have given you the wrong number to send to.
Call those numbers from a regular phone and listen for fax tones.
Aug 19, 2009 | Minolta bizhub 180 Black and White Copier
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Receive faxes but can't send
Instead of trying to send a fax try to call the number from a different phone. To see if the receiver is busy all the time..
Jun 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
