Question about Dell UltraSharp 1907FP 19" LCD Monitor
Vertical band on new monitor
My new monitor has a section consisting of 2 vertical lines about 3cm apart running from top to bottom - giving a 3-D effect of a vertical band. This appears in a different part of the screen with each logon but always the same width. The monitor has not been dropped or subjected to any stress (only out of the box on Friday) and its twin in a dual monitor setup is fine. The effect is very noticeable on a plain coloured background - not on white or multicoloured backgrounds. any ideas on what could cause this and should it be returned to the manufacturer? cheers
  • 472 Answers
Without a second thought, send it back.
When you say the monitor has not be dropped, wht you are really saying is it has not been dropped by you.
There were alot of hands involved in getting it from the production line to your house.
At any stage it could have been dropped or given some form of impact (normally in transit)
That fault is in the panel itself and cannot be fixed.
Posted on May 31, 2008
Vertical Band has appeared on my TH-42PX60B
HI
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Kolbrun
Feb 20, 2012 | Panasonic VIERA Televison & Video
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
167 people viewed this question
Clive
Clive
Alun Cox
