Question about Garmin GPSMAP 60CSx GPS Receiver
GPSmap 60csx hard to turn on and off plus buzzing sound
My GPS has become hard to turn on and off. It only works after a series of attempts. Plus, when I turn it off, the screen goes off, but there's a buzzing sound and it only stops when I take the batteries out.
I sure appreciate your help.
I have the same problem - most of the time when I try to turn it off, it keeps beeping continuously until I take the batteries out. Occasionally when I turn it on it freezes up.
5 Suggested Answers
SOURCE: garmin gpsmap 60csx won't acquire satellites
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Posted on Sep 24, 2007
  • 638 Answers
SOURCE: How to Transfer Maps to GPSmap 60csx
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Posted on Apr 01, 2008
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
Posted on Oct 13, 2009
  • 59 Answers
SOURCE: It does not switch on.
Does it switch on if you press the button really hard? I've seen some with the underside of the rubber plunger not cut squarely, making for a poor contact with the switch on the circuit board. On some I've replaced the entire rubber cap (from wrecked units, not available as a spare part though) or very carefully built p the tip of the plunger with 2 part epoxy glue that sets hard, like Araldite. If still in warranty, contact Garmin of course.
Posted on Dec 01, 2009
  • 58 Answers
SOURCE: Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Posted on Mar 11, 2010
Testimonial: "Many thanks for doing Garmin's job - In my opinion the Garmin hardware is great - the software, documentation and technical support are very poor."
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
Gps 60csx don't get satellites signal level
use the webupdater and replace GPSChipsetTypeG file.
Kind Regards,
Silva.
Dec 08, 2012 | Garmin GPSMAP 60CSx GPS Receiver
While on a road trip my 60csx quit acquiring satellites.
Try downloading and installing V3.70 from here http://www.gpsinformation.org/perry/gps60/
make sure you use the right one for your GPS
Jul 03, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Buzzing noise when i turn off Garmin 60CSx
This problem is Mac OSX related and can be solved using Cleaneject http://www.javawa.nl/cleaneject_en.html
The OSX operating system creates several invisible files and folders on USB-disks, camera's and GPS devices and the Garmin GPS devices can't cope with these invisible files and folders.
Cleaneject erases the invisible files and folders.
Feb 27, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Can not updait a GARMIN GPSMAP 60CSx
Try http://brilliantcorners.org/nodes/87-fixing-a-dead-garmin-gpsmap-60csx. It has helped many people. Complete steps to fix a dead Garmin are listed there.
Dec 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
60CS
Your electronic compass is probably turned on, and if so, either it is not calibrated or you are not holding the GPS unit level.
Try turning off the electronic compass by holding the PAGE button in for a couple seconds. With the electronic compass turned off, the GPS will instead show direction of travel using the current track, which is probably what you are expecting.
Cheers!
May 30, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60CSx
I think all the Garmins allow to do is generate a waypoint list on your PC and upload THAT to the GPS, according to what Garmin told me about my Streetpilot C340. You also need Mapsource on the PC.
Mar 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Dec 31, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 60CSx GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
