Sewing Machines Logo
Posted on Apr 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 974 is not stitching and wont pick up the bobbin thread
Level 3:
  • Singer Master 6,688 Answers
  • Posted on Apr 08, 2012
Cindy  Wells
Singer Master
Level 3:
Answers
6688
Questions
0
Helped
3530022
Points
21744
First check that the needle isn't bent. (The simplest thing is to try a new needle.) Next check that you have a correctly wound and installed bobbin. The hole should be facing up and the bobbin thread comes off the bobbin to the left. Make sure that you threaded the bobbin correctly (notch A at the center and then to slot B to the left. (About 7 if you have the center front of the bobbin area at 6 on an analog 12-hour clock.) Pull the thread diagonally across the bobbin and then close the faceplate with the thread going through the opening of the slideplate. Hold onto the top thread while trying to bring up the bobbin thread.
If the bobbin thread still will not come up, remove the bobbin and clean the bobbin case. You may want to clean under the case as well, see page 81 of the manual. This is page 83 of the PDF: http://www.singerco.com/uploads/download/652_288-974-972-244-2405-588-875-1195-3130-3140.pdf .) Do all of the oiling of your machine while you do this maintenance if you haven't done it in a while.
The bobbin case has several parts that combine to provide good bobbin thread behavior. First there is a tension set screw that keeps the bobbin thread at the desired tension. If it is too loose or too tight the thread can't be pulled from the bobbin. (It's easy to strip the threads of the case, so be very careful.)
This is easiest to check on other types of sewing machines with a vertical bobbin case. For those, you remove the bobbin case and thread the bobbin through it correctly. Dangle the bobbin case from the thread (carefully). The bobbin case shouldn't slide on the thread but you should be able to pull out more thread if you hold the center of the bobbin and bobbin case. (Hold gently so that the bobbin turns.)
Next the bobbin race and hook need to grab the bobbin thread and twist it with the top thread. If these are damaged (perhaps by a bent needle), they won't work properly. These are at the back of the bobbin case.
Try replacing the bobbin case or parts of the bobbin case as needed. The Singer 947 is in the same line as the 244 and should use those parts. http://parts.singerco.com/CPpartCharts/2_2999/240_SERIES.pdf has the parts list. Try contacting a Singer dealer to get the parts. Unfortunately, my usual vendors only seem to list the manual as an available part for this line.
I hope this helps.
5 Related Answers
Anonymous
  • 26 Answers
  • Posted on Mar 08, 2009
SOURCE: needle thread does not pick up bobbin thread it
clean it using a can of air to make sure there is not any fabric or dust caught in the under area. the needle could be bent slighly just replace it.
these are the two things I look for when this happens with my machine. needle is the one most offten causing the problem.
Anonymous
  • Posted on Oct 10, 2007
SOURCE: needle wont pick up the bobbin thread
Can not do by yourself. Mine did the same thing after just having it 3 weeks and I had to take in to authorized Singer Dealer to repair. Now without machine for several weeks and probaly out alot of money for repair. Should have got a Brother!! Hope you have better luck than me.
Anonymous
  • 41 Answers
  • Posted on Jun 27, 2008
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Anonymous
  • 111 Answers
  • Posted on May 04, 2009
SOURCE: Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
sew dutch
Ellen Den Dulk
  • 25 Answers
  • Posted on May 26, 2009
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
My model 800 Zig Zag Deluxe will not pick up bobbin and make stitches, what can i do???
It is usually incorrect threading or incorrect placement of the bobbin carrier.
I have lil sew % sew LSS505+. the needle won't catch the bobbin thread so won"t sew.
Make sure the need is in correctly. if it is backwards or turned to one side too much it wont pick up the bobbin thread. If the needle is in right and it still wont pick up the thread then the machine is out of time.
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. (I don't try to straighten or "fix" damaged needles. With today's computerized machines, it may cause more damage than a new needle would cost. That may work on the old mechanical machines like the Singer Featherweights, but my machines are too important to risk for the price of a needle.) If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
1helpful
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
2answers
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
Machine won't stitch
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
1helpful
Wont pick up
Do this by turning the wheel by hand. The bobbin thread will make a small loop on the way up. Move something thin from front to back, catching the top thread under the needle and the bobbin loop thread will come out. Move both threads towards the back and go!
Kenmore 100 stitch 385 Bobbin thread does not engage into stitch, Needle goes down but thread does not pull up into stitch. Threading bobbin according to diagram on foldout section. replaced the bobbin...
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
3helpful
2answers
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
