Question about Juki TL-98Q
Thread looping underneath quilt
Top looks fine, but underneath looks like a rat's nest. Is it the needle not turned to the right or is there something I am just missing altogether. I am really lost with this and frustrated beyond belief. Any help would be appreciated. I have the Juki tl98 mounted on a bee line quilting frame and have had very little success. Please help!!!
  • 110 Answers
Your problem is the top thread. Make sure you lift the presser lever BEFORE you thread the machine. After threading the machine, just before you thread the needle, lower the presser foot, and test the top tension by pulling down on the thead. If there is little or no tension, adjust the top tension to a higher number, say from 3 to 5, or from 5 to 7, and test the tension again. If you fail to increase the tension by above procedure, look for cotton that might be stuck in the tension blades and remove it. Hope this will help you
Posted on Nov 11, 2008
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
I am a new sewer have a Brither BM-2600 what numbers on the dial do I have for just plain stitching I have tried lots of combinations but the cotton underneath is all bunching up and not sewing right
I am not sure as to your machine, are you saying a "brother" machine? If your tension is set, say on 6 and it is too tight, turn the dial one more a 7 or to a five and then check again. Also, I would rethread the machine and also take the bobbin out and then put it back into the machine. A lot of times, the bobbin isn't threaded into the machine correctly and it bunches up. Also, you can't use certain thick thread on some machines.
Jun 05, 2017 | Sewing Machines
When i first start sewing the thread will bunch up and make a rats nest how do i stop thisa
That is called thread nesting or bird nesting--or what I like to call thread "barfs."
Be sure to ALWAYS RAISE the presser foot when threading the top thread. This releases the tension disk so the thread will seat completely.
Bring the bobbin thread to the top of the fabric and gently hold both thread tails in your left hand while taking the first stitch or two. It may be beneficial to manually turn the handwheel for the first couple of stitches. It also helps to have the take-up lever at it's highest point BEFORE starting to stitch.
Birds nest under the fabric big loops of thread top side looks good...
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
How and Why to Bring up the Bobbin Thread
Apr 01, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
Mar 25, 2017 | Sewing Machines
Underneath of quilt the stitches are long with smaller topstitches is my top tension to loose or too tight
YOur top thread is looping, right? Re-thread your top thread, making sure you floss it into the tension system. When you drop the pressed foot it should offer tension to the thread. Right? When you have underside loops it would indicate too much thread, right? So either the tension is too low OR something is jerking on the top thread causing a loop.
Nov 20, 2013 | Baby Lock Esante
HD 3000 loops underneath work
It's most likely not the machine. It's the other things, ie needle, thread, etc. combination. For sewing knit, be sure to use a ball point needle. The needle eye size is important to so the thread is neither too small nor too large for the thread weight.
FWIW, it sounds like bird nesting. --the thread is not seated completely in the tension disk. Remove the top thread from the machine and ALWAYS RAISE the presser foot when rethreading!
Also, check that the tension is appropriate for the project. The two threads should meet in the middle of the fabric. If there is top thread showing on the underside of the fabric, the top tension is too loose. Tighten it until it until the top thread pulls the bobbin thread up into the fabric.
All About Needles SCHMETZ Needles
Dec 04, 2017 | Janome Sewing Machines
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
Needle sticks on sewing machine and motor won't move it forward
Copy & paste into your browser: You need the free diagrams & details provided on their web site. Jimmy
Apr 05, 2012 | Montgomery Ward Sewing Machines
Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Mar 10, 2010 | PfaFF Quilt & Craft Pro 7530
Juki TL-98Q Logo
193 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
