HITACHI LCD I have this television with too much green back ground and it's missing the blue color I have adjusted the blue color but it's not responding. What could be the problem. I have unplug the T.V. for 6 hours and olug back in and still the same problem. Please advice. Thank You, Phil
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Offhand without a specific model number or better yet a chassis number, I would be guessing that the blue being absent makes the green too pronounced. This being so on an LCD projection made by Hitachi would indicate probable fault with the light engine. You may want to reference this post that indicates Hitachi would supply the part for free. Incidentally, another post outlined how a user performed a DIY (do-it-yourself) workaround.
Hope this be of initial help/idea. Pls post back the model number or chassis number, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
The TV works fine but the screen is green. Color
R G B circuit transistor to be checked. This is located in the picture
tube connecting end PCB. ( Neck ) Check the transistor and its components.
Can be dry solder also!!
Jul 28, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
OUR HITACHI 50V500A HAS COLOR PROBLEMS WE MOVED IT
This is an LCD rear screen projection TV. There is a Red, Green and Blue LCD pallet that is mounted on what they call an X-cube. If all you are getting is Red and green then something happened to the blue pallet. Either the Ribbon connector came off or is loose or something worse. How hard did you mover it?
Another thought. How is it hooked up. If component then this may be the issue as component video connections are Red, Green and Blue. Just a thought.
Let me know.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Philips LCD HDTV -- color problems
I am having the same issue. I believe the issue to be somewhere in the transition between HD channels and non HD channels. A work around is to switch the input to another input such as DVD and then switch back to your cable input (mine is the HDMI input). I'm probing the web looking for why this happens and if there IS a permanant fix.
Nov 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture has gotten darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
HITACHI 60VG825 REAR PROJECTION LCD 2005
seems to me you may have bad color wheel.going to see if i can find out any more information if i do i will post it!
Nov 25, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Color problem
Nov 06, 2007 | Hitachi 51F59 51" HDTV Projection...
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
