Fan motor slow on a/c
The fan motor on my window air conditioner starts out at what seems to be about the right speed for high but varies and slows with time. It does not matter whether the compressor is running or not as whether the fan slows. The fan motor gets hot however the wires leading to the motor do not get warm. I have a new a/c unit, (3 month old). The fan stopped working today and there was a burnt smell so I stopped it. When I checked the motor it looked fine but it would not start. I helped it by turning the fan and it worked. Could it be the condenser going bad? and if so, what would be the reason?
    Genius:
  • 2,035 Answers
If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • OR
    This could the problem the with short circuit or defective component you need to check :
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Good luck....
    Posted on Nov 11, 2008
      President:
    • 1,952 Answers
    MAY I HAVE THE MODEL AND NO MAKE OF THE AC
    • 685 Answers
    Your motor is bad it would be a good thing to invest in new motor or just get a new ac
    Heater/air conditioner motor
    It's probably the fan resistor for low speeds that fried.
    Here's a video on how to replace it on a Volvo V70.
    Jul 31, 2016 | 2000 Volvo V70
    Do you know of a way to slow down the LOW speed fan setting on a Kelvinator KSE70HRA air conditioner? Low is very noisy and blows air like a HIGH setting.
    Hi, no, im sorry if it is on low already, it can't be changed to go any lower. The only thing I can come up with is the fan motored is wired wrong, and they have the high or med lead connected to the low speed, as it should run slow. On a central air system, there is a board that is in the indoor unit that shows the fan speeds, and they can be changed.I didnt look up your unit, and if it is a central air and not a window unit, you can change the speeds at the board. The wires are colored, blue is normally low, red is Hi, and blk or yellow is med. If this is a window unit, there is nothing much you can do. If you know anything about electrical, and you have a 3 speed fan, pull the cover to get to the switch back, and see what leads the have terminated to the switch. They may have it miswired. I wish you the best of luck,
    Shastalaker7
    A/C, Contractor
    Jun 12, 2011 | Heating & Cooling
    Fan noise-fan lags speeds up to normal then slows and will eventually stop. This occurs on fan only operation (high and low) and cool high and low.
    The bearings,or bushings in the fan motor are gone out,the friction eventually slows,or stops the fan motor.
    Jul 01, 2010 | Heating & Cooling
    Air Conditioner seems to be working but the Blower Motor does not come on.
    Some units use a relay to change fan speeds.
    Heat requires a slow speed while cool requires a faster speed, Take a LOOK
    Jul 17, 2009 | Heating & Cooling
    My fan motor runs to slow and needs to be speeded up. The fan motor has been changed to a A O Smith. Air conditioner is a Goodman 3 ton.
    AO Smith motor speeds are Red low Blue med. And black high. Just unplug from fan switch plug in new speed. Turn power of first. Rus
    Jun 17, 2009 | Goodman Heating & Cooling
    Slow fan on Window Air conditioner Sears 106.73220
    if the motor seems like its getting extremely hot it could possibly be seezing up. i would suggest taking your volate reading for the motor and check for proper voltage, also check you amp draw on the motor. the proper amp draw should be on the name plat of the motor. any below the proper amp draw, replace the motor.
    Apr 23, 2009 | Heating & Cooling
    Fan Stops blowing air
    Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
    May 18, 2008 | Maytag Heating & Cooling
    If the fan motor has a capicator it could be bad. A bad cap will pull the motor down. If there is no cap then the motor beatings could be going bad. this can be checked by matching the motor amps with the rated amps on the unit information tag.
    May 17, 2008 | Heating & Cooling
    Heating & Cooling Logo
    297 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
