Question about Panasonic CT-36D11 36" TV
PICTURE PROBLEM piture is pulling in right and left. leaves black line anywhere from .50" to .75". this just started when my cable supplier changed there format. i had cable tech over and he said signal from outside was good. what could cause this?
  • 2 more comments
  • DENNIS ROWE Nov 08, 2006
    WHEN DOES SOMEONE GET BACK AND ANSWER ?
  • DENNIS ROWE Nov 19, 2006
    STILL LOOKING FOR SOLUTION TO PROBLEM
  • DENNIS ROWE Nov 20, 2006
    HAD A NEW FLAT SCREEN TV INSTALLED THAT DAY WITH IT'S OWN DIGITAL BOX AND NO PROBLEM WITH IT.BLACK LINES GO VERTICAL LEFT AND RIGHT SIDES.CABLE IS RCN IN EASTON ,PA. FORMAT CHANGE WAS NEW BAR ON EACH CHANNEL THAT TELLS YOU CHANNEL AND WHAT IS SHOWING.BAR IS BIGGER THAN PREVIOS ONE.
  • 24 Answers
Ok, I'll try. First, I don't trust cable techs. While I'm sure he's a competent person in his own right, When he says the signal from the outside was good, that tells me he measured the LEVEL not the QUALITY. What I need some more info on is your comment regarding "...cable supplier changed their format." What did they change it from [when things were working(?)] and what was it changed to? What city is this cable system in? Did the tech try another box or does the connection plug directly into the set? Have you tried another TV to see if you get the same result? Is the black line horizontal (Left to right) or vertical (Up and down)? This sounds like a sync problem that the TV is trying to lock in on but can't. Let me know what you find, thank you. RY
Posted on Nov 20, 2006
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
The picture frame just turns off after the third photo.
return it to the supplier to check and repair of replace. If there is nothing wrong with it they can explain the issue. The supplier is always the first port of call. It may still be under warranty?
Jun 23, 2015 | Photography
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
I have two sets of black horizontal lines going across my Sony Bravia KDL-52Z5100. If you make the picture smaller the lines extend into the black area that is not part of the picture. After the TV warms...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem...
Aug 06, 2011 | Televison & Video
Double picture on start up
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the coursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of syncs.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck...
May 29, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black lines in tv
Most likely there are electrolytic capacitors in the power supply, video path, and scan amplifiers that are starting to fail from age. This is common in many of these sets. In consideration of the age of the set, this may not be worth having it serviced.
Jerry G.
Sep 24, 2009 | Toshiba 51H93 51" Rear Projection HDTV
No picture
cycle your info button on the bottom left side of the camera.
Mar 18, 2008 | Olympus EVOLT E-500 Digital Camera
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Black comes across right side of screen
Sounds like you've got whats called a cold solder connection somewhere in the horizontal width control circuit or a connection in the sweep section. Should'nt be two expensive but unless you have had some soldering and troubleshooting experience I would leave this on to the pros. Good Luck
Jun 02, 2006 | JVC AV-36D502 36" TV
Panasonic CT-36D11 36" TV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
