Question about kawasaki Full Suspension Mountain Bike Men
Kawazaki ninja zx6r
Hi just got this bike and am having problems when starting it sometimes it just doesnt want to start and after say 30 seconds of trying starts to make a loud ticking sound. it also sometimes just dies when sat in traffic. any help would be most greatfull.
jake
    New Friend:
  • 160 Answers
Sounds like a battery issue
Posted on Nov 12, 2008
I have a problem shifting in to second gear on my 2005 zxr6 636
Hi, Robert and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2nd gear problem help
http://zx6r.com/zx6r/13501-2nd-gear-prevention.html
Kawasaki Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
May 01, 2016 | 2007 kawasaki Ninja ZX6R
Firstly, my bike felt like it was running on three cylinders, reg-rec?
Hi, Peter and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Fuel tank empty.
10. Fuel tank contaminated with ethanol sludge.
11. Water or dirt in the fuel system, or clogged filter.
12. Restricted, blocked or kinked fuel line.
13. Failed fuel pump.
14. Failed pressure regulator.
15. Faulty or clogged fuel injectors.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
http://zx6r.com/zx6r/10307-bike-shuts-off-while-riding-help-please.html
Ninja starts but dies when open the throttle
Mar 14, 2017 | 1998 kawasaki ZX-6R Ninja
Zx6r 2004. Bike ran great for two months. Went out to dinner last night and came out to my bike not starting. Trailered it home, started when taking off trailer. Went for a 15 minute ride and parked it....
Hi, Matt it saddens me to inform you that you have to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
Below is a quick and easy test to see if your battery is in good condition or needs Last Rites and must be replaced.
1. Start by disconnecting the spark plug cables.
2. Adjust voltmeter to DC volts 20-volt range
3. Place the voltmeter leads to the battery terminals.
4. Turn the run/off switch to run.
5. Turn the ignition switch on and press the starter button.
6. Watch the voltmeter as your engine turns over for 15 seconds.
7. If the voltage drops below 9.5 volts, the battery is faulty and must be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ZX6R 636 Bike won start
Kawasaki NINJA ZX6R My bike won start Starter problem or discharged battery
Kawasaki Ninja ZX6R Service Manual
How to Tell if Your Battery is Bad in 3 Easy Steps
May 18, 2017 | 2007 kawasaki Ninja ZX6R
I have a 1995 zx6r running great starting wise but not shifting. The bike run strong in first gears but when shifting to second it only work for about 2 sec then nothing so i shift to third gear to...
sounds like fuel starvation check for blockages in petrol tap, does it only do it reserve?? the 600s are known for crappy reserve internal filter, check the petrol tank breather
Feb 17, 2013 | 1995 kawasaki ZX-6R Ninja
Blowing ignitor [cdi]
Hi, Gemmaj_p123 what is your ignition fuse doing, if your blowing CDI's then I would look for a short coming from the CDI on it's way to the coils, cracked or worn or chafed wiring for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Help fuse blows bike dies bad CDI
ignition fuse keeps blowing
Apr 11, 2017 | 1999 kawasaki ZX-6R Ninja
Having a problem starting
From the information you have provided it is not possible to give you a definitive answer. If you intend to work on the bike yourself you need three things right away. A manual, tools, and an experienced friend.
A manual so you can see and read about the procedures you'll be performing. Tools so you can physically do the jobs. And an experienced friend to show you how to do the things you don't understand in the manual and help you troubleshoot.
My first guess about the source of your problem would be carburetor issues, but I have no way to know for sure.
Good luck.
Jun 01, 2009 | 1995 kawasaki ZX-6R Ninja
Seriously overheating zx6r ninja
With the 05 I would check the thermostat. With the 03 that is normal, my 02 cuts on and off around the same range. I put a switch in so I could turn my fan on when ever I wanted. I run mine once I get to 175...
May 28, 2009 | 2003 kawasaki ZX-6R
Charging problem/no start 95 ninja zx6r
If lights dim when trying to start,Battery is to weak(may have 12 volts but not enough amps)
Bike dieing when removing power from jumper says the lighting coil on the stator plate is bad and this could also have killed the voltage regulator,Which would kill the battery by over charging it.
Hesitation and carbon smell could be from a non firing cylinder.
So,Take the battery and have it load tested (free at most auto part stores)
Check for power from the lighting coil on the stator
Replace the voltage regulator.
Please rate this fixya
May 15, 2009 | 1995 kawasaki ZX-6R Ninja
Hi, Thermostat yes. That is the next troubleshooting step. Good Luck!
Feb 19, 2009 | kawasaki ZX-6R Motorcycles
kawasaki Full Suspension Mountain Bike Men Logo
85 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
