Question about Terk XMD1000 Satellite Radio Receiver
No XM radio detected when I toggle through my sources... also no FM reception
I just got a new JVC KD-DV4200 in dash stereo and a Terk XMD1000 receiver and the Terk JVC adaptor. I have to reset my JVC unit every day because I lose XM reception. In fact, my unit stops recognizing the Terk unit completely. When I toggle through my sources with the source button, it just toggles back and forth between FM and CD mode. However, no FM stations are picking up at all either. Very strange. After I reset the JVC stereo, everything works fine again for a little while. But only for a little while. Has anyone encountered this problem before?
I can not get my jvc kd-r610 on fm radio. lost the manual. help
You can download the manual from the manufacturer's web site at
Why does my xm radio always have to be refreshed after my vehicle has been turned off. The poer to the radio is not lost because the clock is always running. I have to refresh the radio everytime I want to...
You need to have one wire on an always 'hot' power feed. Be careful, as some GM products have a timer that shuts off the power after a 10 minute timer, so that could be your issue. Are you talking about a factory installed XM, or one like the photo above?
Jun 14, 2010 | Terk XMD1000 Satellite Radio Receiver
How do I set time on JVC KD-DV4200?
this links will take you to a page to download the manual, it will help set the time on the unit...and anything else you need
hope it helps..:-)
My xm plays extremely loud thru my car matter what i set the volume is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
Connecting an MP3 player to car radio
The most common way is to use the auxiliary input of the deck or head unit. However I don't believe the JVC model you have has one of these. Don't despair though. Head to your local department store with a music department and pick up a universal FM modulator ($20-$30).
These will 'pretend' to be an FM radio station inside your vehicle. Attach the stereo mini plug to your walkman or other audio device (mp3 player etc.) Then tune the FM Radio to the fm station listed on the FM modulator and you will be able to listen to the device through your car stereo speakers. Now this isn't as clean as a direct hookup but for most its an economical way to listen to alternate sources on your Car Stereo.
Jul 07, 2009 | Sony Car Audio & Video
What do i need to get the xm radio to work
U need to order the Terk XMD1000 Direct XM Tuner Box. Its Search on the internet for it.I bought mine on Cost is 49.99. Its comes with the antenna and box. Your XM radio code is on the box. Go aline and setup an account with SiruisXM and its going to ask for that code. once you do that. Ensure you are not under any cover to get a good signal and it will tell you to go to a certain channel. Then you will be pulled in. if you have any issue contact me at or I will walk you through. Good luck.
Jan 15, 2009 | Jensen VM9510 Car DVD Player
Inside the car there should be a splitter between the stereo itself and the antenna in a side plate
behind the dooor kind of under the dash follow your antenna wire from the stereo you should find the splitter along the way it may have came loose or even off
Apr 23, 2008 | JVC KD-G720 CD Player
Terk XMD1000 Satellite Radio Receiver Logo
48 people viewed this question
Top Terk Audio Players & Recorders Experts
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
