I have same problem as another member, tv turns right off seconds after turning it on, green timer light comes on and goes off, no picture comes on or sound, just a little power zapping sound every time. it worked fine last night!!
Check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
There is a resistor by the high voltage transformer,it has low value and it opens for no reason,he is likely open and does not let the set stay on,if you are familiar with tv service you can replace it and while you are down there check for any over heated areas and resolder them specially the convergence IC.This resistor is located in the back edge of the chassis in the board in the right side and it might be hidden by a plastic casing that covers the high voltage transformer.If you are not too familiar with tv service you should seek the help of a servicer.Let Us know how it goes or if you need more information.
HELLO NEW TO PROGRAM.I HAVE A MITSUBISHI WS-65517 HAVD SAME PROBLEM WITH FLASHING GREEN LIGHT READ A LOT OF POSSIBLE FIX I LOOK AT CAP DIDN'T LOOK BAD BUT REPLACE THEM ANYWAY DID NOT FIX, REPLACED POWER BOARD DID NOT FIX, RERPLACED DEFLECTION BOARD DID NOT FIX,CALLED MITSUBISHI TO GET A REPAIR GUY,HE CAME OUT LOOK AT SET DIDN,T EVEN TAKE OFF BACK COVER GAVE GOOD ADVICE. HE SAID START ON DM3 BOARD THERE IS A SMALL BOARD ON DM BOARD IT IS CALLED E2P BOARD.IT COST ABOUT 100.DOLLARS. I REPLACED IT, PLUG IN,GREEN LIGHT FLASED ABOUT A MINUTE,THEN REMARKABLE SOLID GREEN LIGHT YEA,SET WORKING GREAT.HOPE THIS HELP.
A friend suggested thatI unplugged the TV from the wall and leave it off for 24 hours. I did that and the TV came back for about 5 minutes then goes off again.
I had the same prob w/ my Mits 65 rear proj. Refused to turn on, light only blinked. Was able to correct for free. Opened access panel & noticed wood holding 3 main lenses (Red,Green,Blue) was loose/warping. Tight'nd everything up with a phillips. Problem solved and picture is better than ever. While at it I dusted off interior. Check your tv b4 calling someone. Sometimes the solution is simple.
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
I have a Mit. WS-65809. Power comes on for a second or two with no picture or sound, then clicks back off. Worked fine previously with minor converge problem that would resolve itself after 20-30 seconds. Some suggest to replace power supply, others suggest a oil or gel? from a CRT tube has leaked onto the signal board, and therefore need to replace the board. Not sure if my model has CRTs or not. I'm going to check to see if I have any liquid on the board.
the tv just turned off
I have just experienced the same problem with my TV. Green light for a couple of seconds, zapping type noise and then goes out. Sounds like some good advise here. I would consider myself pretty tech savy but I have never done anything with resistors or fuses with a TV. Does anyone have any pictures as to what the different solutions might look like in terms of where they are located? I have opened up the front panel but definitely don't know where to look.
The tv will not come on.Only the timer lite is on.It is blinking green.What shall I do. I called mitsubishi only to be told to call a repairman. I am totally frustrated with the whole ordeal. Please help me.
Same as other users - TV green light comes on, then goes off with no picture or sound. This is the second experience I've had of the same problem, (the first occurred 8/21/07 - the second occurred December 8,2007, after the original 3-month warranty expired following the repairs on 8/21/07. Told by A-1 Sales & Service it was the "intergrated circuit system #STK393-110" which was replaced. Paid $265,.00 for part and repairs in August.) Mitsubishi manufacturer notified of latest malfunction, said they "might" pay for the second repair. Will know when repair service arrives on 12/31/07. HOW CAN A PRICEY PART FOR A HIGH-END PRODUCT SUCH AS MITSUBISHI WIDESCREEN LAST ONLY 3 MONTHS?
i turn the tv on and it turns right back off
I have a Mitsubishi HD1080 series, Model # WS 65809 series 120458. I turn it on and it turn right back off. What can be the problem?
tv won't stay on. green light comes on, goes off, no picture
i have the same problem the has no desplay and no sound. but the green light continue
yes, TV turns right off right away
turn on then goes right off
I have the same problem. Can we fix it? How much will it cost to fix it?
Thanks
TV IS NOW Â 3 YRS OLD, WONT STAY ON
Same exact issue. Has always worked fine and worked earlier today. Now, it turns on and then right back off again. Any solutions?
im not too good with fuses.. does it cost alot to fix?
green light comes on and then off
error code comes up as 23 horizontal deflection failure
i have same problem as another member, tv turns right off seconds after turning it on, green timer light comes on and goes off, no picture comes on or sound, just a little power zapping sound every time. it worked fine last night!!
I have a similar problem my tv goes from normal to black screen every second and then it takes about a minute or two before it starts to do the same thing but the sound is always there.
TV WILL NOT COME ON,PRESS POWER BUTTON BLINKS POPPING SOND TV NEVER COMES ON NO SOUND EITHER.
