Easier said than done. You have to completey disassemble the front end of the trimmer, remove the clutch housing, clutch, control cables, etc. before the pulley is exposed where you can install a new rope..... If paying a mechanic to install a new rope, it would probably be cheaper to buy a new one.Easier said than done. You have to completey disassemble the front end of the trimmer, remove the clutch housing, clutch, control cables, etc. before the pulley is exposed where you can install a new rope..... If paying a mechanic to install a new rope, it would probably be cheaper to buy a new one.
You can't post conmments that contain an email address.
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Sears
https://i.sears.com > mp-tc > prod_1977954512
PDF
WEEDWACKER GAS TRIMMER. R. Model No. 316.711192 ... 25 cc (1.52 cu. in.) 0.025 in. (0.635 mm) ... Always use the fresh fuel mix explained in your operator's manual.
Sears
https://i.sears.com > mp-tc > prod_1977959112
PDF
Operator's Manual. CRAFTSMAN. 2-Cycle. WEEDWACKER GAS TRIMMER. Model No. 316.711471. INCREDI-PULLMW/TH. UNBELIEVABLE STARTING EASE™. CAUTION: Before using this ...
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
