Question about Mercury P4VM800M7 Motherboard
Connection Process Good Morning Please can you send me a procedure to connect my Motherboard to an ATX P4 casing. The power cable have been done already but remain the power, USB and other wiring. Tai Ajibola
  • 35 Answers
On your atx power supply,there is a 20 pin head wich tou have to put on a 20 pin socket on the motherboard.about the usb and other wiring,study your motherboard carefully and you will see where you will put the usb,power switch,reset switch,hdd led and power led
Posted on Nov 11, 2008
How does P4 Connector connect to the CD Rom Drive
Hmmm, P4 is usually a designation, for a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
I see though that they have P2 as the 4-pin ATX +12 Volt power cable, and P4 as a SMALL 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
This type of power cable is used on a Floppy Drive, or a Card Reader.
Not a Harddrive, or Optical Drive. (CD/DVD drive)
The Standard 4-pin Peripheral power cable, is used on an IDE (PATA) harddrive, or optical drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Rounder corners on the Top of the plug connector.
Only plugs in, in one direction.
Owner's Manual > Page 109 -
Power Supply DC Connector Pin Assignments
P1 = 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
P2 shown above - 4-pin ATX +12 Volt power cable
P3, P5, and P6 are SATA power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
If you have a SATA optical drive (CD/DVD drive), the above is the power cable used.
Uses a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
SATA data cable connector on motherboard, is shown below the SATA data cable.
NOTE*
Color does NOT matter
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 09, 2012 | Dell Inspiron 531s Desktop Computer
P4M800PRO-M V 2.0 NEED MANUAL TO CONNECT FRONT PANEL OF THE CASE POWER, RESET, HD LED ETC....
I have found the manual for your P4M800PRO-M V2.0 Motherboard. The connection diagram is on page 18 of the PDF file or page 12 in the manual. You will find the manual here: http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/P4M8OOPRO-MV2.0.zip or by clicking Here.
Hope this helps. If it does, please accept and rate the solution! You can leave a testimonial or contact me with any more questions you may have. Thanks for using FixYa!
May 26, 2011 | EliteGroup ECS P4M800-M Socket...
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
I Just bought a Corsair Cx-500W P4 ATX power supply, but I can not connect it to my Asus P7P55D-E/LX P55 LGA1156 motherboard because of to many cables(confusing)
You need to connect the 20 or 24 pin connector to the ATX power slot on your motherboard, its the long rectangle one. You will also need to connect the CPU power to the CPU power slot, that is the 8 pin one. I hope this helps.
Feb 26, 2011 | Computers & Internet
Micro ATX motherboard ATX case?
Two possible causes - either you have installed it badly and it shorts to the case (take it out of the case and try it there) or not all the necessary cables were connected (check especially the power cables and the power button).
Jul 13, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
Motherboard power problem due to atx 12v cable
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Jun 09, 2009 | ASUS P5P800-VM Motherboard
MSI 845E Max P4/845E/FSB 533/HT/Audio/ATX Motherboard
Try this link..http://www.nodevice.com/driver/845E_Max/get37906.html
Jun 26, 2008 | SIS741GX-MN Motherboard
Codegen Case LCD
INSTRUCTIONS COMES WITH MOTHERBOARD,NOT THE CASE
Jun 19, 2008 | Computers & Internet
PC wont Boot/start
try another graphics card if you have a working spare
Feb 16, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Mercury P4VM800M7 Motherboard Logo
139 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
