Question about Hoover HTC243 Top Load Washer
How to remove agitator
I want to remove the agitator to see what is underneath causing a grunching noise when the agitator works.
The nut? at the bottom of the centre of the agitator seems to turn around but nothing happens.
  • Anonymous Mar 26, 2014
    agitator in a lg wt-h9556 how to get at noise underneath
    Genius:
  • 1,239 Answers
Hi The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Posted on Nov 11, 2008
Why does agitator make a kinda grinding noise and machine will not spin?
some foreign object jammed under the agitator ???
unplug machine and use coat hanger to fish it out from underneath
Jan 19, 2016 | Washing Machines
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
How do i remove the agitator
Top of agitator has a removable cap. Try to unscrew, if not pry off. You should find a hold down nut underneath. Remove nut, then pull evenly the agitator.
Sep 01, 2014 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Clothes stuck under agitator
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
Washing machine agitator is loose and makes a lot of noise. Can't figure out how to remove the agitator
Remove top cap of agitator (it may need to be gently pryed up or simply popped off). Under the cap is a large nut which needs to be removed. With the nut removed simply pull the agitator up.
Feb 19, 2010 | Whirlpool OEM FSP Washing Machine Pump
How to remove the agitator??
remove agitator cap ,,looking down in agitator removre the plastic seal with a firm yank,,now you can see the agitator hold down nut,,remove that bolt with 1/2 inch nut driver or wrekit,,pull agitator..if clothes is jammin it down take you belt and slide under agitator,,and pull booth ends ,,but away from your fast ,may come up fast..always unplug
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
How do you remove the agitator if something is caught underneath.
On a Maytag the agitator either has a bolt under the center cap, or a set screw along the side about 3/4 of the way down. Maytag Alantis and Performa models have a removable agitator cap with a bolt underneath, while the Dependable Care series have a set screw. In either case, you loosen the nut or screw, and the entire assembly will lift straight up. Sometimes they stick and require a little effort to remove. I hope this helps you.
Sep 04, 2008 | Maytag Washing Machines
Hoover HTC243 Top Load Washer Logo
436 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
