No sound, no power; I checked all connections
    Sergeant:
    Champion:
  • 283 Answers
Change the power supply cord, but if doesn't work then change power supply. Thank you
Posted on Nov 11, 2008
No sound
Possibly an internal power supply failure
Nov 10, 2013 | Polaroid Televison & Video
Woofer stopped working
If power problem then change power socket. If power come then may be sound plug problem so you check it. If power ok, then not correct connect to PC. So you check it which point you are connect to woofer. If externally ok then open PC and check your sound driver proper work or not go to control panel- click sound and audio and check it your software working or not. And one time full computer scan and clean virus. If not solved go to computer technician and take support.
Thanks
Oct 26, 2013 | Altec Lansing Acs340 Computer Speakers
Windows, wiper, radio, dash dimmer wont work i have tried the relays and fuses
Now try checking ALL the ground wires connected to the frame under the dashboard. If any one of them is broken off or loose that is a cause of multiple outages.
Jan 13, 2013 | Cars & Trucks
No power from battery
See if you fuse box is getting power
Jan 11, 2012 | 1992 Ford F350
The power appears to come on, but no picture and no sound
Look at power board. check fuses on board and replace fuses with new ones.
Hope that helps.
Dec 22, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
No sound produced, but power green light is on but dim.
make sure you have a good ground contact, bolt connection to body and make sure to sand off paint where you are screwing ground connector.also check that you have good 12volt(power) & remote wire connection. if that is good check for a good connection with your rca jacks. with that you should get sound.
Apr 13, 2011 | Car Audio & Video
Subwoofer not working.... JVC surround sound system 778V Subwoofer Part Number SP-PW37-SUB I hear a hum coming from unit so there's power going to it. I hear weak bass thumps with volume turned all the way...
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
Dec 05, 2010 | JVC RX-778V
No sound after connection? Power is on! Computer
Check your Sound Device if it is installed correctly
Jul 03, 2010 | Creative Labs I-Trigue 3220 Computer...
Has power and connectivity but no audible sound
check if you have the ethernet cord conencted correctly from router to VOIP phone
and also check if you have internet conection
Apr 28, 2010 | Linksys SPA941 IP Phone
No sound coming from sub woofers amp is connected and powered properly,all connections are correct,i have checked all connections to head unit,to battery i have disconnected and re connected all...
check your amp fuse also any car fuses, then check inside the sub box at the connections as they dont come connected when you buy it, try that 1st
Jul 11, 2009 | Car Audio & Video
Computers & Internet Logo
David Payne
David Payne
