Question about Panasonic CT-20G13 20" TV
Tuner and AV problem
Hi....i have two problem on my panasonic tv....first, can't find channel at VHF-H and UHF band, only channel that using VHF-L was ok. second, i've lost my AV sound, but for tv sound is ok....the picture for AV also good. please someone to help me........what component are in trouble?
TRY TUNER ASSEMBLY SOLDER JOINTS COULD BE DRY OR CRACKS GOOD LUCK
Posted on Jul 05, 2007
SOURCE:
I have a Curtis Mathes tv/CZ2026RE I need to get to channel 97 for my DVD/VCR to work but cannot get to it, HELP PLEASE
Hello
Channel 97 comes in UHF band. If you do not able to tune this channel, the tuner of your TV may need repalce ment. Now it is OK with respect to VHF bands.
Feb 04, 2012 | Televison & Video
I have a mga tv 1988' model cs1946R. I only get 11 channels from comcast my cable provider, my other tv (newer) get all channels. How do I programe my old mga to get more channels( I know i won't get as...
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
Sep 18, 2008 | Televison & Video
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
Jan 27, 2009 | Curtis RT700 7 in. Portable Television
Would you confer with me on this couple in Australia
If they are looking for analog ABC, it is low band VHF, ch2 to be exact,where the rest are high band VHF, and needs a decent multiband antenna to get it in alot of areas, well in Brisbane at least. We have Mount Coot-tha that has a good propagation to most metro areas approx 40km radius, although it starts to get a bit noisy on the ABC due to lowband interference issues. .
There are many areas of AU that use UHF for TV also. Not enough hills in many parts of the east coast to get the coverage, so there can often be UHF translators that you need to tune onto. I suspect the ABC problem does relate to them not using an antenna that is suited to VHF, saying this of course if they get the other channels (7,9, and 10) ok.
Go here for a more specific channel/frequency guide to determine if it is the problem by location. ABC is on different channels almost depending on what suburb you are in for some areas. If the DVR can do digital, then they should go that way as it is now UHF ch21. It may be that they are trying to get analog signals, that will be turned of in the near future... so tuning the system in for UHF propagated digital is the way to go.
Back in the day when I used to do antenna I recommended the Hills PF11 antenna, multiband 11 element yagi with low/high band VHF/UHF, or a PF17 (17 element) with mast head amp if they are in a marginalised signal area. But a UHF array is still the best way to go if they can process a digital signal. Hope that helps :)
regards
robotek
Oct 23, 2008 | Televison & Video
RCA VCR VMT 385A support needed
c is cable
h is hi vhf (7-12)
l is lo vhf (2-6)
u is uhf (13 and up)
Dec 31, 2007 | Televison & Video
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
a no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Jan 24, 2007 | Zenith B25A10Z 25" TV
Panasonic CT-20G13 20" TV Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
