Question about Rex RX-1804
Bobbin My bobbin thread won't draw up and so it won't stitch at all. It was sewing fine and then it got bunched up on bobbin thread while making a buttonhole. When I got the tangle out, it stopped making stitches. Now I can't get the bobbin thread to draw up. I have changed bobbins, rethreaded countless times, taken shuttle apart and cleaned, etc. I have never had such a problem. I have only had the machine for a few days. Thank you. Sally
  • 3 Answers
Take hold of the top thread and pull it securely through the needle guide, hold and turn the wheel and then pull the top thread to bring up bobbin thread. Check to make sure there is a long length of thread coming out of the bobbin first.
Posted on Nov 17, 2014
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Posted on Jun 15, 2009
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
When using buttonhole attachment, machine does not move instead sews in one spot and collects thread coming up from bobbin. Any ideas?
make sure the buttonhole option is chosen
and then pull down the buttonhole lever
it should come down against the buttonhole foot
Apr 25, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
Sep 21, 2012 | Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
My bobbin tension thread is bunching up and not sewing right, top stitch is fine? I've moved the tension control number each way and this does not help at all. I've tried different bobbins also? Help!! ...
Recheck your bobbin and make sure it's in the bobbin case correctly.There may be arrow diagram on face plate or bobbin case. You can also check owner's manual to make sure bobbin is inserted the right way. If it isn't, the bobbin thread can "whiplash" causing the bunching you've describe. If you have smooth stitches on top, your top threading is all right. I hope this helps. If it does, please let Fixya know by rating my solution.
Nov 30, 2010 | Singer Stitch Sew Quick Sewing Machine
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Robbie
Jan 31, 2010 | Elna Sewing Machines
Tangled thread
Ask at the shop where you bought it, take a sample and arrange a time to meet & discuss if it is under warantee.
Jul 30, 2009 | Brother CS6000i Computerized Sewing...
Problem while sewing buttonhole with a thick thread
You will need to use a size 18 needle or even better a size 18 top stitch needle. It has a larger eye.Tighten the tension to about an 8 and try it. You may have to lengthen the stitch length to make it sew satisfactorily.. If it won't work on 8 go to 9 and if it still won't work, wrap the thread around the bobbin winder guide (on the left top of the machine) for more tension. It is very hard to sew heavy duty thread on a household machine.
sewman7
Jul 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Rex RX-1804 Logo
247 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
deaususa
MissFixIt828
Level 1 Expert
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
