Question about Air Tools & Compressors
I need a wiring diagram
I cant find out about this general electric motor that gos with a air compresser, Is this one of a million quistion or is every body out there just plain well you got my point, there is no wiring diagram on any part of this air compresser so all ineed is the manual on this
  • ian stalker May 11, 2010
    hi
    is the unit 1/ single ore 3phase 240/415v
    2/star delta or direct start
    is your machine single phase or three phase
  • 98 Answers
If you can tell me the compressor model # maybe i can get you a diagram or a little info on what you need as far as a diagram.
Posted on Jul 21, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Evinrude outboard diagrams
There should be two separate wires
Dec 10, 2013 | Boating
Wiring diagram
Have a look on the inside covers, often a wiring diagram sticker is placed on it.
Sep 21, 2013 | General Electric APE08AK Portable Air...
How do you wire a 240volt 1.5hp single phase electric motor that has a capaciter involved?
You don't give enough information for a specific answer. The following information generally applies. There should be a wiring diagram under one of the covers or on the metal name tag. Often there are two screw terminals inside the motor's wiring box, along with a bunch of push-on "spade" terminals used to switch the wiring for 120/240 or maybe 240/480V. The screw terminals are most likely for the power input connection. It doesn't matter which wire goes where on a single phase motor. But you need to know the motor is "set up" for the proper voltage (and rotation), which is why you need the wiring diagram. You can search for the diagram on line. The capacitor (if only one) usually connects in electrical series with the "start winding" both of these are then often switched off through a centrifugal switch once the motor is up to speed. These are then connected in parallel with the run winding(s). (Some motors have both "start" and "run" capacitors). Of the two windings, start, and run, the start winding usually has more resistance. If the motor has the ability to operate at more than one voltage this can add two more windings and up to four more wires to the puzzle, it can then be difficult to determine the proper place for all the wires if they have been removed or mis-connected. Electricity is my profession, yet I have not been able to figure out all the motor windings I've encountered while using the above information and an ohm meter. Unless you are a pro (in which case you probably wouldn't have asked this question), or if all this doesn't make sense, you might try finding a motor repair/rebuild shop near you and have them show you the proper wiring. Technically a motor this large should be installed by a licensed electrician.
May 23, 2013 | Heating & Cooling
I need help wiring in a new speed control on my bosch table saw 4000. The new speed control came with a large black wire, a small black wire and a small blue wire. The large black wire was easy and I...
ts4000 Bosch motor wiring (post #210578, reply #6 of 7)
by emils01 in reply to emils01 [original] on Tue, 09/30/2014 - 15:50
So I called Bosch on Monday and they were well informed and helpful. They emailed me a schematic and explanation of ...
4000 PCB wiring diagram.
1. White AC line cord to white field wire.
2. Black AC line cord to thin blue wire on PCB.
3. Black motor field wire to thin black wire on PCB.
4. Black long, thick wire on PCB to red motor brush wire with push on connector.
Sep 18, 2017 | Bosch 4000 - 07 Electric Table Saws
Motor growls & low torque. Need a wire diagram to check for proper wiring.
I'm not sure what happened on here, but your problem with a motor is listed under the heading for a 200amp main breaker. What kind of a motor are you talking about? Gas, electric? what brand what model?
Aug 19, 2010 | General Electric GE ELECTRICAL TQD22200X2...
Hi, I have a general electric model number 5kc182ag201d motor that I want to change from 110 to 220 volts. wiring diagram lost but the wires still have the numbers on them. Also I want to change the...
This can only be done if the motor has the function to be switched. But as for reversing the rotation it is very complex, if you have starting capacitors on top of the motor then it would be required to change the wiring at the diodes and wire the starting capacitors opposite of their present configuration. This is really something for an electrical motor rewinder to address as it is over the heads of most folks. It can be done if you had the wiring schematics and the motor has the features built in for this. micmor68@gmail.com
Oct 29, 2009 | Air Tools & Compressors
Need a wiring diagram for 5kcp39fg general electric motor
if it has a brown/purple,and black wires and is a single phase motor, the purple and black are your 2 hot phase wires, and the brown goes to the motor capacitor and on other motor cap term that goes back to the purple phase wire
Sep 26, 2009 | Heating & Cooling
Coleman air compressor
Should be an electrical diagram on the motor. The motor name plate should also indicate if it is a dual voltage motor. There should be a cover on the end of the motor to access the terminals.
Aug 30, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
622 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
