Question about Refrigerators
Icemaker will not make ice on it's own. #GD25DIXHS02
Ice maker will not make ice on it's own. If water is added it will make ice. What can the problem be.
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 1073 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Posted on Jun 24, 2008
  • 27 Answers
SOURCE: no ice in the icemaker
there may be some problem with water inlet solenoid valve. the coil or valve could be faulty
Posted on Mar 10, 2009
  • 9 Answers
SOURCE: Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Posted on Apr 02, 2009
  • 81 Answers
SOURCE: no water getting to ice maker
The freezer is likely too cold and the water line has frozen. Aim a hair dryer at the incoming water line after removing the cover pane.
Posted on Apr 24, 2009
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Whirlpool Gold icemaker won't make ice
    Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
    If the ice maker does nothing then replace the=>
    2198597 Ice Maker Assembly
    Thanks John Tripp Appliance 911
    Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
    My icemaker has stopped receiving water
    it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
    you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
    May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
    Ice cube maker not making ice
    feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
    Apr 29, 2010 | Maytag MFI2568AE Side by Side French Door...
    Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
    Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
    If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
    Caution. If the fill tube going into the ice maker is filled with ice do NOT
    use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
    Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
    Oct 22, 2009 | Kenmore Refrigerators
    Whirlpool IceMagic Plus not working.
    Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
    The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
    Sep 14, 2009 | Refrigerators
    Icemaker
    Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
    Let me know if this helps.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    one of the 2
    Jun 23, 2008 | U-Line Icemaker
    Refrigerators Logo
    42 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
