Question about Sunon (16-02-006) Fan Kit
Dell dimension 8300 no power
I got a tower from a friend he told me power supply was bad so i replaced with same power supply green light comes on from board but front button wont turn on no green or blue or yellow led and no abcd lights on in back of tower no smell processor looks and smells fine computer was in a electrical surge and was told caps leek does this make sence and how do i fix thanks
    Problem Solver:
  • 17 Answers
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Posted on Nov 11, 2008
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Dell dimension E521
If its a desktop unit have someone open and examine the power supply for puffed up caps---if this problem usually it will begin where have to try to turn it on a few times and then it gets worse.
if puffed up caps you have two choices---replace all the ones that have this issue or buy a generic power supply to install in the tower.
see typical caps--if not perfectly flat or showing any brown material coming out of top or bottom they are bad.
4_30_2012_8_53_01_pm.jpgnote the two here with tops puffed up.
Apr 30, 2012 | Dell Computers & Internet
When trying to turn on CPU the power button only blinks yellow but cpu dont come on
The power supply is likely bad. Check the back and see if it has an LED lamp - I think it's a green color near where the power plugs into. If it's not lit or is flashing, then the power supply IS bad.
Feb 10, 2011 | Dell Dimension 8300 PC Desktop
The power light on my dell dimension 2400 is orange (it is not blinking). The loading light next to it is green. the computer is on but it will not do anything.It wont show the dell logo or anything. What...
You May hev one of two problems, either you towers power suply is broken, or on of the system fans are not working.
Check the power supply fan on boot. If its working check the CPU fan
Regards
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 2400 hit by lightning. the green
it can be one of 2 things:
1. if the battery charge light is all that comes on then you motherborad is busted.
2. if the power light turns on without the screen showing anything then you will need to replace the screen, but first connect it to an ordinary PC monitory and see if it works from there before changing anything.
Jul 18, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Power problem
check for unplug wire coming from the front panel if there is nothing unplug you may have to change your power supply or if you have a power supply tester check it first if not i'm kind of sure the problem is your power supply rate me
Jan 13, 2008 | Dell Dimension 4600 PC Desktop
Sunon (16-02-006) Fan Kit Logo
948 people viewed this question
Top Sunon Computers & Internet Experts
David Payne
David Payne
Are you a Sunon Computer and Internet Expert? Answer questions, earn points and help others
