Question about Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washer Won't Drain (Model #417.40052990)
This happened one time before after washing something that had way too much fuzz come off it. My hubby was in Iraq, so I found instructions on line detailing how to clean the trap (I'm not sure if that's the correct terminology). I can't find the instructions again.
We're pretty challenged in this area, so the step by step instructions I had found before were great. Any help would be appreciated. Thanks.
P.S. I couln't find the product in the final question, so I put the closest thing. Thanks again.
  • 38 Answers
The machine knows when there is water left in the tub and will not function properly because the level switch indicator is still open.Ok, to simplify this ,you have a clogged pump and if there is no access into the machine from the front then look at the back to see if there is.Open the panel and remove the hoses from the pump and remove what is caught in it.Also look into the ends of both the 2 hoses.Don't wash RUGS,MOPS,COIN MONEY,NAILS,JEWELERY,UNDER WIRE BRA'S,OR ANY THING THAT DOESN'T BELONG IN THE WASHER,cause these little things don't make it past the pump,therefor washer leaves water inside and error messages start rolling.
Posted on Nov 11, 2008
I have iPhone 4 I want start sync.me I work in Baghdad Iraq but I don't found country cod so what can I do
The might problen might've occurred becouse of your location that you are in, the camera/phone is American made so it is set to US time zones, to fix this problem make sure the dates on both the camera and phone are the same time and make sure they are set to the appropriate time zones, any questions, contact me
Aug 13, 2013 | Photography
Tip
Hubby followed your directions. WOW, found 3 PUREX washing sheets in the drain....
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Oct 01, 2010 | Kenmore Elite 45986 Front Load Washer
The cd player wont work on my durabrand hm3817dt
It may not be as random as you think. The cause of this type of failure is that there is a sled motor which drives a worm gear. This worm gear can accumulate dust and fuzz over time and the little motor in there is not a 1 horse power type device either. What happens is the pickup lens is scanning the data and at intervals it has to move a little bit to be able to read the disc again. If there is something that is resistive to the movement- hard grease or fuzz or the bad spot on the motor commutator then you come across this symptom. You might clear the problem for a while by putting a disc in and advancing it to the last track and then back to 1 a few times- this exercises the sled mechanism so that it may clear the debris that is stuck in the worm gear. If you continue to have a problem at intervals, then the sled motor needs to be changed and they are not so easily found and take a lot of labor to put in as they are buried deep in the mechanism. Just so you know.
Oct 01, 2012 | Audio Players & Recorders
Hi im frome iraq icannt found easy server in any
that will be because iraq is blocked from the comunication servers
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
THE WASHER WILL STOP BEFORE THE CYCLE IS DONE AND WATER SETS IN THE TUB AND WON'T DRain
Mine does this all the time... the first time i had the repair guy out, he showed me where you take off the front cover and open the drain and sure enough, lots of fuzz from rugs was clogging the drain of the machine, $108 to show me how to unscrew the drain cover!!! It is happening again, just 5 months later and i have found no fuzz in the drain, so i had repair man out today and now it's my water pressure switch is out, BECAUSE i used too much soap! I use half the recommended amount!!! Switch won't be in till next week! Did i mention how much i hate this machine!!! I want my old top load back!!!
Feb 22, 2011 | GE WSXH208A Front Load Washer
We have a lexmark e232, we where printing and then it stopped and the exlimation symbol keeps flashing, we rest it, and tried cleaning it, we have no idea what to do about this we are in iraq and there is...
I'm in Iraq too. the printer has no lcd which i find to be uncommon. Take out the fuser and see if there is a paper jam. otherwise an online manual could help decipher the "!".
May 09, 2009 | Lexmark E232 Laser Printer
Camera turns on and off
mite have fallen down from a height better take to service center
Dec 09, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
Red lines and burn in
Hi: Did you get yours fixed? If not whould like to work a deal to buy it I figure if I can get 4 or 5 sets I can make one good one out of them!
Nov 19, 2007 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Kenmore Elite 45986 Front Load Washer Logo
744 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
