Question about JVC AV-27F803 27" TV
JVC 27" AV27F803 Brightness fades to dark intermittently
My brightness or screen color dilemma is different than those posted. After viewing the tv for a short time, the screen will immediately turn dark. It doesn't slowly fade to this condition, but goes from normal brightness to dark rather quickly. Current Conditions: satellite (dish network) Components not used full time: Monster Power Center HTS 3500 Denon Receiver AVR 3805 TV is not directly hooked up to either the Power center or the receiver. It has an Independent outlet.
  • jeff berger Nov 09, 2006
    Thank you for your direction. In fact, I did test the back of the TV and found that every time I hit the control board, the picture would turn bright, dark, or blue. There is definitely a control board, video card problem.
    Thank you for your assistance.
    Sergeant:
  • 337 Answers
I likely you have a loose conection in the crt board at the neck of the picture tube or a loose conection close to the high voltage transformer,I would suggest to tap the main board as well as the crt board with a wooden or rubber handle(not metal),be attentive were you tap to see if the set reacts ,if the set reacts you will need to resolder those places ,be carefull working on a set that is on while you do it,this should give some idea what the problem could be in case you want to call someone to help you with the repair.Let Us know if you need more information.
Posted on Nov 06, 2006
  • Omar Urrutia
    Omar Urrutia Nov 06, 2006
    Your rating response is also important.
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
The color on my JVC is way off. It is dark and faded.
I have recently come into a JVC tv and am having problems with it, but all i can tell you is to access the menu and check the picture and brightness on the tv. hope this helps
Feb 25, 2010 | Televison & Video
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
Analog tv with poor color and brightness
probably tshe picture tube; time for new set
Mar 28, 2008 | JVC AV-27230 27" TV
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
JVC AV-27F803 27" TV Logo
131 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
