Question about Whirlpool Royal A-909 Bathtub
Whirlpool does not work
We just purchased a new house as is, and it has a Royal whirlpool tub...unfortunately, it doesn't seem to work! The motor doesn't even make a sound. I can't find a model number, just the name Royal. Any suggestions on where to start to find the problem? I've taken off access panels but can't actually see much but pipes, and a side of what I assume is the motor. Thanks for any ideas!
-Heather
  • avejewelry Nov 18, 2008
    Thanks for the suggestion, but I don't think it's Nordic, and they had nothing helpful under their troubleshooting section anyway. But thanks for trying!
I have a Royal whirlpool bathtub as well and found the following site very helpful to me: whirlpoolbathtubs.biz (it was not preceded by a www.) You might also try calling the Royal Company in Houston, TX
Posted on Sep 15, 2013
    Genius:
  • 1,605 Answers
I think it is manufatured by Nordic.?
this link should help you will all the installation use and repair.
http://www.nordichottubs.com/owner-center/default.aspx
let me know if this is not the one.
please post additional comments in this thread.
Posted on Nov 18, 2008
How do you install a new on/off switch in a royal whirlpool bath?
The switch is located on the back of the pump. If you have access to the pump and you can see the tube coming out of the black box on top of the pump you might have a chance of changing it without pulling the tub, If you do not have access to the pump, one will have to be made or pull the tub for repairs. If the pump can be removed this might also make the repair go easier. The switch is available at most pool or spa stores. If you are uncertain about doing this repair call a Jacuzzi certified repair technician to do the job.
Jul 06, 2014 | Whirlpool ROYAL BRB826 Corner Tub, Jacuzzi...
Air jets
is there voltage going to the motor?
Rod
US Parts Center
Jun 24, 2013 | Maax Calla 6042 Bathtub - 101058-000
Aker swrilbath tub want change jet colors
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Apr 06, 2013 | Whirlpool Royal A101A-R Bath Tub
Control panel has power but pump doesn't work
Check the volage coming out of the control to make sure you have 120v. It could be the control is bad.
Pull the pump and plug it into a 120v outlet. If the pump is good it will come on. If it is not working then it will not come on and will need to be replaced.
Rod Kidman
US Parts Center
Ph: 888-521-6183
Fax: 801-417-8027
"Chat Live"
Apr 05, 2013 | Neptune DB60TAM Whirlpools and Air Tubs
Where can I buy just the brass trim on the jet for my whirlpool tub (aker)?
The trim for any brand whirlpool (w/p) tub must be ordered from that specific tub manufacturer. They will need to know exactly what your particular model is.
The model of your w/p tub, and serial number, is most often, but not always, located on the motor end of your unit but not on the motor itself. Access to this end of the tub, if installed to code, should get you the information you need, otherwise you are out of options'
Jun 03, 2010 | Whirlpool Royal A-909 Bathtub
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
New house, just over 1 year old, came with Royal whirlpool tub. I never used it. Today when I tried to start it, it just does not come on. I donot have a manual and cannot find one online. Any help please
First you want to trace and check if the unit is tripping the circuit breaker in the fuse panel of the main house. Next you want to take the top two bolts of the control box(within the body front of the tub) and remove them. pull the cover downward towards the ground. Next you want to trun a hairdryer from an extension cord(make sure your feet are well guarded from the wet surface should this occur. Using the hairdryer, dry all of the exposed components of the box and it's housing. This is precisely what a hottub repair reprentative would charge you $100-$150 to do, not including travel time. See I just saved you more than you'll pay for this info...lol. Put the screws back in and close up the body of the tub. You should be good to go. Thank you, Dana
Sep 30, 2009 | Whirlpool Royal A-909 Bathtub
The jets don't work..I don't hear the motor at all. Do I need to get a new motor? I have a Royal bathtub. The motor is next to the tub under the sink w/ a cover.
It could be the motor, but don't rule out the switch. If there is a small plastic tube that exits the back of the pump/motor, there is a switch attached to this tube. The switch is avaliable online and can be installed after removing the pump from under the tub so that there is room to work on it. To check the pump, remove the switch and tape the two wires together, quickly plug the pump in and them unplug it to see if the pump comes on. Do not run the pump for more than a second or two as pump seal damage may result.
Sep 22, 2009 | Whirlpool Royal A-909 Bathtub
Noisy dryer, looks like drum is warped perhaps?
this sounds like a problem i've had with whirlpool super capacity dryers and since whirlpool bought out maytag about that time then u may actually have a whirlpool. The tub is actually out of round. a new tub might fix it(with new felt etc.) but the super tubs seem to be weak and easily bent. new felt may buy you some time though.
Jun 13, 2009 | Dryers
How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Sep 28, 2008 | Home
Whirlpool Royal A-909  Bathtub Logo
346 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
