Dear Friend
it not show any errror code
its only shown " Install developer"
pls Give me the solution how can i solve this problem
bcz nobody here for sharp service.
You will need to get some developer. Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum. Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter. If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
this is ccd white correction , clean the opitus really good and under the plat on the right side make sute there is no condisation or dirt on white plate
Hi friend,
Thanks for your assistants
there was a problem in developer unit pin(PJ Jack)
i found and solve the problem
once again i thank to u my friend
