Question about Seagate 250GB Barracuda 7200.10 ATA-100 Internal s - 16MB Cache (5-pack) 250 GB EIDE Hard Drive
SECOND HARD DRIVE NOT RECOGNIZED
SEAGATE BARRACUDA 7200.10 250GB HD 8MB SERIAL ATA-300 0EM---WINDOWS XP PRO.
ONLY TWO SATA CONNECTIONS ON MOTHER BOARD-ONE CONNECTED TO MAIN HD W/OP SYS. I CONNECTED THIS SECOND HD WITH A SATA II CABLE TO THE OTHER. WINDOWS ALERTS THAT NEW HARDWARE DETECTED, BUT THERE IS NO ICON/LETTER LISTED IN "MY COMPUTER"? I CAN FEEL AND HEAR THE HD RUNNING, SO IT HAS POWER. CHECKED DEVICE MANAGER AND IT LISTS THE NEWLY ATTACHED HD AND SAYS IT'S RUNNING PROPERLY? HOWEVER, CHECKED DRIVE MANAGER AND IT'S NOT THERE? DO I NEED TO DO SOMETHING IN THE BIOS? I HAVE INSTALLED IDE HDs BEFORE WITH NO PROBLEM, BUT SATA DRIVES APPEAR MORE DIFFICULT. APPRECIATE THE HELP, JOHN
  • 38 Answers
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Posted on Nov 11, 2008
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
you will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try ebuyer.com
Mar 31, 2015 | Seagate Barracuda 7200.10 (ST3750640AS)...
Seagate barracuda desktop 3tb no being recognized
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Mar 03, 2017 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Nov 25, 2009 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
I require a driver for a seagate barracuda 7200.7 160GB hard drive
Seagate and Maxtor-brand External Hard Drives
External drives contain a standard computer hard drive in an enclosure that makes it possible to connect it to in of your computers external data ports (USB, FireWire or eSATA). This makes it easy to add a drive for backup or data storage to any computer with a compatible external data port.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">external hard drives
do not require additional drivers to function in Windows Vista
Microsoft Vista is the successor to Windows XP operating system. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows Vista
, Windows XP
Microsoft Windows XP is the successor to Windows 2000. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows XP
, Windows 2000
Microsoft Windows 2000 is the successor to Windows Me.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows 2000
, or Mac OS X
Mac OS X is the operating system that is produced by and comes standard on Apple computers.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Mac OS X
. These external drives are supported by the standard device drivers that are already included in these operating systems out of the box. Installing Serial ATA drives requires the installation of drivers from the Serial ATA motherboard. Click here for more information on this subject.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201413&NewLang=en
Oct 25, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Windows XP not recognizing the hard drives
On the first drive that does sound DOA if you bought it new, is less than one year old and the warranty hasn?t been voided you should be able to get a refund from the manufacturer. Second drive, have you tried connecting the drive enclosure to another computer as a test? If it can?t read the drive data either I would suspect the enclosure electronics are faulty. Also have you tried the firewire interface yet? Semper Fi, are you active or former?
Apr 29, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate 250GB Barracuda 7200.10 ATA-100 Internal s - 16MB Cache (5-pack) 250 GB EIDE Hard Drive Logo
403 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
