Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
Freeze while recording
I have a Hauppauge WinTV HVR 1600 running under Windows XP.
At random times the wintv 2000 program will freeze during a scheduled recording. CPU goes up to 100%. Program will not end when I hit X. When I try to kill the program using Windows Task Manager, I get the message "The system cannot end this program because it is waiting for a response from you" but I see no indication of anything needing a response. Any ideas?. I have to kill it or reboot to make the computer useful again.
Lawrence Hannon
4 Suggested Answers
SOURCE: Hauppauge WinTV HVR-1600 - ATSC HDTV receiver
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Posted on Nov 02, 2008
SOURCE: WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Posted on Feb 28, 2009
  • 617 Answers
SOURCE: WinTV HVR-1600 not working when I upgraded from Vista to Win 7
get drivers for win 7 for card
Posted on Feb 05, 2010
No sound in Hauppauge WinTV radio under Windows 7 64 bit
Driver issue? I would go to the manufacturers website to check for compatible software...
Mar 20, 2017 | Hauppauge Televison & Video
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Jan 06, 2010 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Freezes
You may not have enough computer power to run it. Try shutting down some running programs to see if that helps, if that doesn't do it you don't have enough computer power. Those takes a lot memory to run.
Nov 15, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV-HVR-1600 running windows XP on ATT uverse I can not get the TV Tuner card to pick up any channals I have tried the bundled SW and a thrid party software results were the same. I...
Most likely, all stations in your area have switched to Digital Transmission, and your card can no longer find any. If that is the case, then you need a new card (they are not convertable) sorry.
Aug 19, 2009 | HP Hauppauge WinTV-HVR-1600 NSTC/ATSC Tv...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wintv stuttering when watch channel, but is fine when record it
Further update: Have downloaded SageTV, and it works fine with the Hauppage card. Is definitely a software problem. Have also tried total uninstall, reinstall, with same results. Also downloaded GBPVR, and it also worked with the card.
Jan 03, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Open Questions:
See all Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / Questions
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
69 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
