Question about Compaq Presario 1626 Cooling Fan Case Cooling Fan
COOLING FAN DOESN'T MOVE
TOYOTA CAMRY LE 2001, DOESN'T NOT WORK WHEN THE ENGINE IS RUNNING, IT MAKES THE RADIATOR GETTING HOT AND ANTIFREEZE GOES OUT AND HOT FROM RADIATOR
  • OIPINGNG Nov 11, 2008
    NEED HELP, IS FAN GOT PROBLEM OR OTHER
    I FOUND OUT WHEN I TURNED THE A/C ON , BOTH FANS ARE WORKING. ARE THEY GOOD THAT MEANS. WHAT CAUSE THE RADIATOR GETTING HOT WHEN I DRIVE THE CAR LONGER? ARE THE FANS SHOULD SPINNINGALSO WHEN THE CAR IS RUNNING WITHOUT THE A/C ON?
    Scholar:
  • 42 Answers
Your fan motor is broken. Take it to a mechanic.  Run the heater on full blast at its hottest setting to help keep the radiator cool while driving to the mechanics. Open a window if u need to!
Posted on Nov 11, 2008
I have a 2001 Toyota Camry that is overheating. I can smell burnt antifreeze. The radiator is full of antifreeze, but the reserve tank drains quickly. It appears there is no circulation. There is a small...
The overheating could be a stuck thermostat, or a failed water pump among other things. If you are loosing coolant faster than the leak on the hose, you may be burning it out the exhaust pipe. Which would point to engine problems.
If the temp gauge is not showing the engine is hot, and the fan is not coming on, what you are smelling may only be the drip blowing onto the exhaust pipe. The engine may not be running hot.
A mechanic would use an infered thermometer or a scanner to "read" the engine temp to verify it is overheating.
There is a chance the system is not actually full and has air pockets in it which would need to be bled out.
Jul 20, 2012 | 2001 Toyota Camry
I have a 2001 4.7 SLT 2x4 Dodge Durango. Some time ago the car would overheat and spit water/antifreeze from the readiator cap over the battery. I replaced the radiator cap. A few weeks later, it...
if the fan electric fan is not comining on, you need to check the fan motor to see if your motor is bad on the fan. check it by running a hot wire directly from your car battery to the fan elecrtic plug.
Jun 20, 2011 | 2001 Dodge Durango
My 1989 toyota camry drives fine but when engine is turned off the temperature raises causing the radiator to overheat and dump antifreeze
you need to check if the cooling fan works, and that the radiator is clean, you may even have a blown head gasket. a shop will need to diagnose and recommend repairs.
Dec 14, 2010 | 1989 Toyota Camry
I am not sure if the radiator fan is working on my 92 v6 camry its not over heating but never see or hear the fan running is there a fuse or relay that might have gone out. I cant even see any wires that...
The radiator fan in the 92-95 models of V-6 Toyota and Lexus vehicles is a weird design. The fan is not electric but runs off the power steering pump. The power steering pump moves fluid through hoses to the radiator fan, thereby creating its rotation. A sensor monitors coolant temperature and signals a solenoid on the power steering pump when more or less cooling is needed. The power steering pump then speeds up or slows down to provide more or less fan speed.
This system seems to work pretty well. However, there is a connector that goes to the power steering pump that is critical to proper operation. In engine work this connector often gets overlooked when reassembly is done. This results in the fan running at constant speed and not increasing rotation when more cooling is needed. This becomes a problem primarily when the car is idling or moving at a slow speed.
If your car is not overheating in these situations, the fan is probably operating okay.
Oct 20, 2009 | 1992 Toyota Camry V6
What can cause water to get very hot and be pushed out into the the coolant reservoir in a 1993 Toyota Camry LE v6?
Several things ... best guess, in order:
1. (very likely) Radiator fan is not blowing (turn on car and a/conditioner. When compressor kicks in, the radiator fan must blow). If it ims not blowing, the radiator fan motor may be burned out ($40).
2. Check / replace "cooling fan" fuse ($1) and / or "cooling fan" relay switch ($7).
3. Could be (not likely) thermostat sticking shut. Replace thermostat ($20)
4. Could be radiator hose collapse (not very likely) ($18)
5. Radiator clog or hose leak (possible)
6. Head gasket broken (not likely unless you don't fix current problem) ($150)
The more detail of the symptoms, the better we can assist you.
Hope this helps!
Sep 19, 2009 | 1993 Toyota Camry V6
Car running hot 1993 toyota camry. it has new engine head, new fan, midas did a radiator flush check to see if it was that. checked water pump said no its not the reason the thermator is not in the car...
You should have a thermostat in the engine. It allows the water flow to speed up or slow down as needed. Also, make sure your antifreeze is set for 20° BELOW zero.
Jul 03, 2009 | 1993 Toyota Camry V6
Engine coolant indicator
make sure that your fans are working first. to do this. start veh and let idle until it warms up. but if it starts to get hot and fans do not turn on, check fuses. if they work then look for leaks.
May 20, 2009 | 2001 Toyota Camry
Radiator fan on my 1994 toyota camry
there are actually 3 temp sensors. 1 is on the top of the engine that goes to temp gauge in dash has 1 wire. next to it is a 3 wire sensor for engine control and choke. on the bottom of the radiator next to the hose is a 2 wire sensor. loosen all 3 but leave connected. get engine hot past halfway point on dash gauge. with ac off disconnect 1 sensor at time. start with 2 wire under radiator. it takes the most abuse. fan will come on when you disconnect broken sensor. 2sensor must agree for fan to stay on till engine cools when turned off. note this is solution i used after verifying fuses, fuseable links and relays worked.WOO HOO! make sure you check both the fuse box under hood and fuse boxleft side of steering wheel my ECU fuse was inside my bros was outside.ECU B on my car goes to nothing and is under hood. Had it confused with ECU on wiring diagram.DOH!
Jan 18, 2009 | 1994 Toyota Camry
TOYOTA CAMRY 2001, WHEN SHOULD THE FANS SPIN?
when the car is running, there is enough air to cool the radiator, however, when when the AC kick on, the radiator absorb more of the heat from the AC coil. there by require more cooling. the 2 fan are there for that purpose.
as far as the smell of antifreeze, you nee to check all of the cooling hoses, in the engine compartment and under the dash. sound like there is a small leak some place.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Compaq Presario 1626 Cooling Fan Case Cooling Fan Logo
386 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
