Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Closed Caption on Sony Bravia
How do i Turn off Closed caption on Sony Bravia TV. My CC1 is Off and I have Cable box and i dont see CC on Cable box.
  • 320 Answers
Try a master reset on the TV. With the TV powered on, prss and hold down the up button on the remote (there are 4 buttons grouped together for up down left and right) and while holding down the up button, press the power button on the TV. The unit should power off and then turn back on and ask you to select a language. Let me know if this helps and be sure to rate this solution. Thanks!
Posted on Nov 11, 2008
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
Cannot get closed Caption to work on TV
Long and short of it....you have to go through the process with the cable box.
Sep 21, 2012 | Sony Bravia KDL-26S3000 Television
How to turn off the close caption on tv
Hello
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Jul 08, 2011 | Philips Magnavox 20MT133S 20" TV
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Closed caption problem with Sony Bravia KDL-46S5100
CALL SONY NUMBER SHOULD BE UNDER SUPPORT ON YOUR MENU SYSTEM MIGHT NEED SOFTWARE UPGRADE THEY CAN SEND YOU ONE SHOULD HAVE USB INTERFACE. ALSO IF YOU ARE ON CABLE TRY RESCANNING CHANNELS IF YOUR ON SATELLITE MAKE SURE CC IS IS SET ON, ON SAT REC
Apr 12, 2009 | Televison & Video
Closed caption for sony trintron analog tv
Closed Caption will not turn off. Model: Sony Trinitron
Jul 24, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Closed caption
There are external close caption boxes that you can add to your system. But be aware: many cable boxes do not process the close captioning information "through", forcing you to use the close captioning on the cable box.
Dec 02, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
632 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
