Back to:
Tags:
GE 25GT516 TV
Dark picture and shadows
posted by penelope066 on Nov 06, 2006
i was removing my dvd player from my cable box as it is no longer supported and was checking to see if my t.v. had the right connections in the back for the dvd player. I played around with the plugs in the back one labeled " F " and one " S " and that's when the colour on my t.v. went extremely dark. i tried fixing the problem with the menu by resetting to factory settings , didn't help . i checked all connections and plugs but nothing helped , picture is still dark and fuzzy with shadows . please help
Comment by penelope066, posted on Nov 06, 2006
thanks for the quick response ....ok the connectors at the back look like the plugs on the newer t.v's where you can add a vcr , game or dvd player . they are black and set back in the back of the t.v. . there arn't any switches anywhere , just the two plugs ... " F " being on top and " S " being the lower .i can give you serial number if that helps 256T516TX1 ....
Comment by penelope066, posted on Nov 07, 2006
looked closer " F " is focus and " S " is screen ...
well i didn't turn them , i thought maybe i could plug the red , yellow and white cords in them as being an older modle they would look different but i definitly did not turn them ...
Comment by penelope066, posted on Nov 11, 2006
ok thank you anyway ...
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
rix20601
Rank:Master Master
Rating: 84%, 40 votes
Sounds like you've entered the "service mode" where you're seeing the chroma (color) signal only.
What type of connectors are the F and S? RCA? F?
This set is no longer made which makes it hard to research. By any chance, is there a small switch on the back that says "normal - service"?
Comment by rix20601, posted on Nov 07, 2006
OK, I think there is some confusion here. The focus and screen controls are not plugs; they're screwdriver adjustments that a technician would turn when aligning the set. Did you turn these?
rix20601
Comment by rix20601, posted on Nov 11, 2006
It sounds as though there's a failure in the screen circuit. I think the next move is to take it in and let a tech take a look. I just don't see the quick fix here because something happened between the cable box and the TV when the cables were changed out.
I wish I had the real answer but another pair of eyes needs to see the problem.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dark picture and shadows:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
GE 25GT516 TV
how can i acces to the menu without the remote control
GE 25GT516 TV
i press the menu button in front of the tv, but nothing...
GE 25GT516 TV
my tv just shows channel 99, it doesnt change channels,...
GE 25GT516 TV
my son press many buttons from the menu button and now it...
GE 25GT516 TV
I hooked up everything, but
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
