Question about Whirlpool Duet GHW9150P Front Load Washer
Stops Spin and Drain - Displays an F02 or a Sud
Our Whirlpool Duet (4 years old I believe, maybe 5) has started to behave intermittently badly. On occasion, though more often of late, a load will not complete the spin and drain portion of the normal cycle. It will stop and the controls will be frozen. I cannot cancel the cycle or change to anything else until I unplug the washer. Then, if I let it sit for several minutes, I can run the drain and spin cycle and it will work. Sometimes there are no issues at all. The loads are sometimes heavy, sometimes not. We do not always get a code, but sometimes I see F02 or Sud. I took off the back cover to check the belt, which seems to be in fine condition. I ran it through the diagnostic as indicated by the document inside the washer. The all seemed to function as indicated.
I am fairly handy at small repairs, so if there is something I can do to fix the washer on my own, I would like to do that and avoid the large service bill. Your assistance and time are much appreciated.
  • stmpublic Nov 11, 2008
    Actually the model is a ghw9100lw.
    I did just that after perusing this site. No significant debris in the filter or around the pump. A couple small pins and some hair around the spindle of the pump propeller. I ran the diagnostic cycle again.
    It seems to complete just fine. The only oddity is that the water pump seems excessively noisy. I do not remember that from before. It seems to have a sort of oscillating grinding noise. Would a malfunctioning pump cause this problem? That seems easy enough to replace.
    Thanks for the help.
    Scholar:
  • 64 Answers
Q. "It seems to have a sort of oscillating grinding noise. Would a malfunctioning pump cause this problem? That seems easy enough to replace."
A. Yes the pump could be the cause of your problem....and especially if it is making a grinding noise.....If it was me I would replace the Pump....good luck
cbinny1
Posted on Nov 11, 2008
    Scholar:
  • 64 Answers
You will need to first remove the front cover below the loading door... there will be 3 Phillips or Torx screws on the very bottom of this cover. After you remove the front cover you will see a white cap in the very center bottom. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect...) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover.....please make sure the washer is unplugged before you remove any covers......let me know if this helped...
cbinny1
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
Potential Causes
It stops in the middle of a cycle and gives an F02 problem.
F02 Long Drain
Potential Causes
Aug 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
Potential Causes
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
149 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
