Question about Ruud Heating & Cooling
LOOKING FOR WIRING DIAGRAM FOR A URGG-05E30 JKR RUUD PACKAGE UNIT
2 Suggested Answers
muttandjeff
  • 359 Answers
SOURCE: Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Posted on Nov 08, 2008
WIRING DIAGRAM FOR RUUD URGG-07E37JKR
Just go to the following web address. Hope this helps!
https://www.google.com/search?q=Ruud+model+URGG-07E37JKR+wiring+diagram&rlz=1C1SKPL_enUS
Jan 17, 2015 | Ruud Central System Air Conditioner
Wiring diagram RUUD UAPA-036JAZ
the condensor gets 240 volts a-c and 24 volts a-c to control contactor. pretty straight forward on this 3 ton unit. the 240 volts comes off breaker box and the 24 volts comes off thermostat and common of transformer.
Jun 10, 2014 | Ruud Heating & Cooling
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
Where can I find specs on two older RUUD models: URGG-05E30JKR & URGG-05E24JKR?
what kind of specs are you wanting. try to google the model#. It should take you to where you need to go
Oct 27, 2009 | Heating & Cooling
What size is my ruud gas pack
you have a 92' three ton unit in the mod # the 37 signifies 37000 btu, and the servial number states that it was made in the 44th week of 1992.
Feb 06, 2009 | Ruud UAMB Air Conditioner
Cool air through vents
I replaced the unit it was very old
Jan 25, 2009 | Ruud UBHC Air Conditioner
Combustion Fan runs all the time
the schematics sould be on the back of the door panel
Jan 06, 2009 | Ruud UAMB Air Conditioner
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
RUUD model URGG-10E31JKR GASS PACK purge fan and main blower
if the purge fan wont start on its own see if there is a capactor attached. if not replace it. more than likely you cannot lube the bearings in your blower motor. the new fans are not serviceable.
Oct 29, 2008 | Ruud Heating & Cooling
Sep 20, 2008 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
77 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
