Question about GE JVM1651 Microwave Oven
No power on the pront panel
All LEDs off on the front panel, looks like no pwer, but when open oven door, light inside oven turn on? any idear? Thank you.
  • hailin2000 Nov 11, 2008
    Thank you.
  • hailin2000 Feb 03, 2009
    I fiixed this one with changing control panel
  • 108 Answers
Any repairs or parts you buy In my experience will not be cost effective. Consider replacing the unit. The newer ovens are reasonable, and have many new features.
Ray
Posted on Nov 11, 2008
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
Door Switch- SCA2001 FSS 02 GE Advantium 220v
a parts diagram would be useful here..let me go see what's available
Apr 01, 2008 | GE Advantium SCA2000B Microwave Oven
Panel mulfunction , GE Microwave Oven Spacemaker XL1800 JVM1850WH
It sounds like a bad filter capacitor on the circuit board, which we repair often, and possibly a bad door switch.
We would need to know you full model number from the tag in or on the unit.
FixYa does not currently notify us experts when someone replies to help requests, so you would need to post a new help request with the same info you did, but include your full model number.
Apr 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
How to open the control panel to troubleshoot no power failure condition?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | Whirlpool GH7155XHS Microwave Oven
Siwtch door stuck open,
there is a switch on the front usually inside the back bottom latch it pushes on a switch in the back of it as you close the door.
you have to remove the top cover to get to it.
you can insert a plastic knife to test it. you should hear a click and light should turn off.
it may be jammed or open inside the switch .or wire is off. etc..
May 12, 2008 | Whirlpool MH1140XM Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Keypad problem
The most likely causes are a bad door switch or a problem with the control panel assembly. You can find critical safety information plus our information file on checking and replacing door switches at our site, via our poisting here: http://tinyurl.com/yzjozk If you need control panel repair, we do that for $32.50 nationwide.
Jan 24, 2007 | Kenmore 62622 Microwave Oven
GE JVM1651 Microwave Oven Logo
128 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
