Question about Symbol LS2208 Handheld
Like to know how to program the ''+'' key.
After I scan a barcode, instead of pressing the "+" key on the keyboard to bring up the new screen. i would like to program it to just scan the "+" barcode label instead.
    Problem Solver:
  • 8 Answers
Adf rules
send all that remains
send extended key <enter>
send ascii key <+>
so it does this sends barcode presses enter
sends + then presses enter
Posted on Dec 23, 2008
New Toshiba labtop. Computer went into sleeping mode How do I bring back desktop screen?
Try to move your mouse/touchpad or press any key on the keyboard. If the machine doesn't wake up, push the POWER button to wake it up.
Jun 13, 2011 | Computers & Internet
Good day, I would like to know what are the keys to do print screen with that keyboard, as the PrtScn button doesn't seem to work when pushed alone. Actually, I'm not able to do any print screen with this...
After you press PRINT-SCREEN,
click Start.
Click All Programs.
Click Accessories.
Open Paint.
Click Edit.
Click Paste.
The image that you "printed" will can be manipulated, and eventually printed, using the 'Paint' program.
Nov 26, 2010 | Computers & Internet
Hi, I have restaurant pro express v 12.0. Is
You could program a key at bottom with the ON SCREEN KEYBOARD function using the TOUCH SCREEN SETUP. This will let you manually type in the item number or bar code number. One thing to note, if you do not use bar code numbers as your item numbers, you can still make this work. On your inventory screen, click on the green check box beside ALTERNATE SKU. Then type or scan the bar code and ENTER and SAVE. You now have both an item # and bar code # that will reference your items.
Nov 07, 2010 | Pc America Restaurant Pro Express
How do I get the Euro symbol on an ASUS keyboard to operate as it is in tandem with the figure 4?
Whenever there is a symbol to the right of a key, using the Alt Gr key pressed down and then that key tapped, brings the relevant symbol up. Also works if you want an acute accent instead of going to character map, i.e. ?, ?
Oct 15, 2010 | Computers & Internet
Symbol LS2208: Suffix with 2 x ENTER
You may need to enter two "rules", each adding an "enter" to the data. This is programmed by scanning special barcodes in the manual, which you can download here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Aug 27, 2009 | Symbol LS2208
How do I use keyboard to print off a copy of the desktop icons?
Shouldn't be any different except the key may say PrtScn or Print screen on the Microsoft keyboard.
Mar 19, 2009 | Computers & Internet
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Oct 17, 2007 | Symbol LS 4278 Barcode Scanner
Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Symbol LS2208 Handheld Logo
405 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
