Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Generic problem for all Refrigerators
Need two trays for sharp
oldbag46 on Nov 11, 2008
need two trays for sharp sj-25j-wh
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 11, 2008
Not Rated)
micbeth1981
Rank: Guru
Rating: 88%, 445 votes
go to sears .com,click on parts,put in your model number get your part,cross check the price at repair clinic .com-mike
Was this helpful?
Yes
No
Related Problems
I had my GE side by side for about 2 years. Things have...
GSH25KGRBB i got this frig it click on and off and on and...
I bought the defrost heater unit and the connector does not...
Can you Help with these Refrigerator problems?
fridge and freezer stopped cooling. ...
Solve
fridge and freezer stopped cooling. seems like fan blowing, but not blowing cold enough air. fan in... (More)
Model #56541-56551 water leaks from...
Solve
Model #56541-56551 water leaks from freezer side of a side by side fridge
adjust doors
Solve
adjust doors on 42 in. built-in ref. door is saging
ice stuck together when falls into...
Solve
too much water is dispensed into water tray to be frozen causing ice not to separate when falls into... (More)
How to change the temperature...
Solve
How to change the temperature setting for the freezer?
Sponsored Links
Describe your Fridge problem:
Select a Category:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(800) 440-8583
http://WWW.SUBZEROLOSANGELES.COM SUB-ZERO...
A1 Service
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
