I have a HP a6013w, I have 2 spare IDE Hard drive I am trying to install one with a IDE to SATA adapter. I have all devices hooked up and the light on the adapter is on and the extra HD is running. So I go to my START button and pull up MY COMPUTER the HD in installed does not show up. Do you have any idea what I need to do?
    Scholar:
  • 61 Answers
Check the jumper settings on the hd one has to be a master for operating system and the rest has to be the slave drives .... sometime certain hd's may work under cable select and make sure cables are seated correctly and no bent pins jumper needs to have a snug fit use a toothpick to remove or bend pins straight..
Posted on Nov 11, 2008
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
Can I install a sata 1 tb hdd on my Presario S6500nx using a connector converter
how old is your computer ? if not to old you should have multiple sata-contacts.you can*t only have one ide-contact about the the connetion yes it's possible there is adapters for it.
Apr 09, 2013 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Should the sata cable be hooked up to the cd drive or the hard drive and where can i find pictures of where the inside cables should be attached to
One end of the Sata Cable is to be attached to the CD/DVD (Optical Drive) or Hard Disk, whereas the other end is to be attached to the motherboard. The Sata connections on the motherboard are located near the CMOS/RTC Battery as indicated below: - (Blue, White, Yellow and Black, at right-hand top corner)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | HP Pavilion a1540n PC Desktop
I want to install a Barracuda LP Harddrive 2 TB/TG will it hook up without an adapter garypdavis@msn.com
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
Apr 18, 2011 | ASUS A8V-MX Motherboard
Hi i have Toshiba HDD2194, i want to connect it to my PC with USB Cable, please can somebody help me to find which kind of adapter i use ?
OK just go to say, Ebay, or your local PC store, and buy a HDD/DVD, SATA/IDE - USB "Dongle" Pack, they are real inexpensive, simply use the interface that matches your HDD the "Dongle" has BOTH connectors, hook up the Power to the HDD/DVD and hook up to the PC via USB, to the PC, the PC, should "See" the device, and install a "Driver' then it should be available in My Computer, as a normal "Drive".
Example below.
http://cgi.ebay.com/USB-2-0-IDE-SATA-S-ATA-2-5-3-5-HD-HDD-Adapter-Cable-/180550148600?pt=LH_DefaultDomain_0&hash=item2a09a0a1f8
Apr 01, 2011 | Toshiba (HDD2194) (hdd2194-50pk) 60 GB...
Want to know whats the maximum hard drive i can put in my pc it as a bv cuba ms-7301
Generally, you can put 2 devices (hard drives or CD/DVD drives) per IDE chain and 1 device per SATA port. It appears there are 2 IDE chains and 2 SATA ports, so theoretically you could have 6 hard drives hooked up (assuming you don't use an optical drive). Four would need to be IDE, two SATA.
Mar 27, 2011 | Packard Bell (181368) Motherboard
How do i find my hp compact ,the model # to look for the manuel for my comp, i have a hard drive i guess it's a new type and i want to add another hard drive but it's the old conection, what i can do ,,
I assume you new hard drive is a SATA hard drive and your HP only has an IDE hard drive.
To install a SATA hard drive in the HP, you will need to install a SATA controller card in your HP so the SATA hard drive can work in the HP computer. You will also need a power adapter lead for the SATA hard that converts the 4 pin power connector to a SATA power connector.
Mar 10, 2011 | Compaq Computers & Internet
IDE drive install in SATA computer
can you remove a disc drive and use the hard drive in the original ide slot?
you pci adapter may not work with your motherboard, not all cards are compatible with all boards.
Feb 27, 2009 | Maxtor Hard Drive
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
