Question about Ecoquest Flair Air Purifier
Sparking My Older Flair Ionizer has started sparking while running. This sis a new problem and we have newer ceramic plates. What do I do? It is loud and is leaving an area where it appears burned on the ceramic plate.
    Scholar:
  • 68 Answers
You got new plates they offer no support by phone? Could be some kind of dirt or contamination, the transformer could be shorting or sparking, write me at wbwill@sbcglobal.net or look me up on allexperts.com, it may be worth mailing to me and let me estimate repairs,
Posted on Nov 12, 2008
I JUST REPLACED THE OZONE PLATE IN MY XL15, THE GLASS PLATE HAD CRACKED BUT, NOW THE NEW CERAMIC PLATE WHISTLES LOUDLY WHEN ON ANY SETTING LESS THAN MAXIMUM?
Remember the glass plate is thicker than the ceramic. The whistling may actually be arcing of the metal tabs to the plate. Take the plate out and push the metal tabs in and towards the space where the plate sits. This will make the fit tighter and eliminate your problem. Re-install the plate.
Jul 20, 2011 | Alpine Air XL-15 Air Purifier
There is a blue spark and bug zapping sound-looks like its sparking on the ceramic ozone plate. The place looks fine-no cracks.
It's doing exactly what it's supposed to do. The bug zapping sound is from dust particles in the air, that's being pulled thru the unit. However, it should not being doing in continuously (unless your home is really dusty), it may simply need cleaning. Cleaning the unit, about once a month is recommended.
Hope this helped you.
Jun 16, 2011 | Ecoquest Flair Air Purifier
My Flair smells like it is burning and the plates are making a loud sparking sound
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 01, 2010 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
Sparks shooting down sides of ozone plates
Disconnect the power and give it a good cleaning with a SOFT BRISTLE PAINT BRUSH. Outside is best. Blow it out gently with canned air after you brush the dirt loose.
Jul 25, 2009 | Ecoquest Flair Air Purifier
Clicking is likely sparking/arcing rather than something mechanic
Sparking is what it does; Google the words ionizer purifier sparking and you will be let to explanations on how they use sparking to clean. Honeywell has been using that Technology for decades. Don't worry sparking in the unit is OK
Jul 12, 2009 | Brookstone Pure-Ion (506840) Air Purifier
Flair sparking
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Flair Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
Fan motor is dead I think...is it okay to run ionizer still??
no , it is not advisable to run the machine while there is an exsisting problem , it would be best not to run it untill the motor has been replaced
electech
Nov 07, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
200 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
