Question about Pioneer Car Audio & Video
When head unit is removed from radio why does the lose its setting
    Brigadier General:
  • 6,966 Answers
Initially, pls confirm that the yellow wire is connected to a constant B+12 such as the + terminal of the battery. The red goes to a switched B+12 such as the ACC/IGN switch. If problem persists with the two pre-conditions satisfied, then there is an internal fault to the unit's logic circuitry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
Why is my eurovox radio flashing then shuts off in 4 minutes
sounds as though the radio requires the radio security code to be entered. This is often supplied with the manual / handbook - have a look for this first and then enter it. The radio code is often required if the car loses power / flat battery, removed battery, fuse etc. If not you may need the serial number of the unit (may have to remove the head unit) and possibly the VIN vehicle identification number of the car and contact Volkswagen. I did find this site but it is in Oz so I doubt it will be applicable but you never know...http://www.go-tech.com.au/faqs.html
Oct 07, 2014 | Volkswagen 2001 Eurovan Radio / CD Player...
Removing radio unit from 1998 Nissan Maxima
FIRSTURN OFF CAR take keys ou look for a rectangular face plate plasti. take off . thfind th e screws take them out and dont lose .. then slowly pull head unit ou . there is a bundlr of wires that goto a connecter that connects to anoyhter bundle. un hook at clear connector i said
Jan 24, 2014 | 1998 Nissan Maxima
Loses memory
you have the memory lead on the radio wired up to a switched wire, this wire needs constant power, like straight to the battery or to a constant power source in your fusebox.
Dec 10, 2013 | Cars & Trucks
CDX-GT4301P sony car radio loses station/settings memory intermittently.
At the back of the head unit, there are usually two power connections to the car battery live. One is via the ignition, and the other is (usually) a fused connection that connects directly to a relay or fuse that has constant power, even when the car is switched off. This constant power allows your head unit to hold its memory. If the loss of memory is intermittent, it could be a loose cable or corrosion on the fuse.
Oct 22, 2013 | Car Audio & Video
How to remove the care stereo
Carefully remove the trim plate around radio, (clips into dash)
Remove screws and pull out radio
Disconnect radio connectors on rear of unit and antenna cable
Reverse procedure to install...
Mar 26, 2009 | 2001 Daewoo Lanos
Problem with radio in vw sharan
First remove the unit so as to access the power and ground leads. Then with a voltage testers ground lead attached to the head units ground wire operate the unit as normal until the shutdown happens. Then test both power supply leads for 12+ vdc (one is a constant 12+ volts memory feed and the other is a switched 12+volts for operating functions)
If ether of these do not register 12+ volts then you need to find a different power source. If they do register 12+ volts then the problem is in the head unit. In which case if you are emotionally attached to that unit then have it serviced, if not replace it.
Note: A replacement may be cheaper...
Good luck
Aduz
Mar 23, 2009 | Kenwood KDC-MP4028 CD Player
When car turned off&on, settings & radio stations stored are lost
There should be a red wire and yellow wire with connectors in the middle. swap the wires over, so red plugs into yellow, and vice versa.
Jan 08, 2009 | Kenwood Car Audio & Video
Mk4 head unit not working
Hello There.
Thats an interesting one. My first suggestion would be to look at the DVD navigation unit in the trunk, does it have any sign of life, i.e will it eject the map dvd is there a blinking redlight etc, if there is nothing then thats most likely your problem if there life in it then I would suggest having a closer look at all the connections in the trunk. You need to remove the side cover in the trunk and check the connections.
If the above doesn't help, my guess would be your head unit has the fault.
The cheapest way to get this repaired is by process of elimination. If you think the DVD unit in the trunk is faulty I would buy one from ebay if you find this doesn't solve your problem you can always resell it on ebay without losing money and the same with your head unit.
Hope this helps. Good Luck.
If my answer has helped you, please rate me on Fixya.
Many Thanks.
ILikeBMW
Nov 12, 2008 | 2003 BMW 330
XM Direct 2
On the adapter cable if there is a separate cable for power connect the positive directly to battery power as opposed to ignition. The memory resides on the xmdirect2 module not on the head unit.
Oct 04, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Keep losing radio presets
Most current car head units requires two (2) kinds of B + supply; the yellow should be connected to an always on/constant B+12 such as the positive terminal of the battery. This is responsible for the memory and setting/configurations not to be erased when powered off. The red wire is connected to a switchable B+12 such as the ACC terminal of the IGN switch making the radio work only when the key is turned to ACC. Of course,the black is ocnnected to the chassis/ground.
May 16, 2008 | Sony CDX-GT100 CD Player
Car Audio & Video Logo
29 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
