Question about Video Game Consoles & Games
Name sorting using c++
Can you please write c++ program that will accept 10 records of name in sort ascending and descending order. thanks
  • Benjamin Patri
    Benjamin Patri May 11, 2010
    I know c++ but I think that if this is a homework assignment, then for one you should do it yourself. You just need to use a strut. It is pretty simple and then you just need to write a function to sort them and you may need a few other functions but I will let you figure it out. Let me know if I am right on this being a homework assignment. If you start it, I would consider looking at it but I won't do it for you.
  • 3,037 Answers
Since you haven't replied for a week, I assume you didn't want my help and so I expect that you don't rate this solution. If you still want help, I will provide it, but I won't write what could potentially be a homework assignment. I can give you guidance if you get stuck. good luck
Posted on Nov 19, 2008
  • Kaleb Hawkins Oct 05, 2012
    I think he was expecting spoon feeding...
When I save a word document file to "Documents" they are no longer being saved in alphabetic order? Whats gone wrong and how do I fix it?
When you open that folder ( or any other), you have the option to sort by file name, file type, date, etc... Click on name at the top, and it will switch to sorting that way. Click it again to change from ascending to descending and vice versa.
Nov 12, 2012 | Acer Aspire™ T180 PC Desktop
I'm following all of the steps to sorting a list - but when I go back to look at it, it did not sort. Please help!
Enter the data in any order in your list. Press [2nd][Quit] to exit the data editor.
In Main screen, press STAT, select SortA( for ascending or SortD( for descending order.
The command echoes on main screen as SortA(. Press [2nd][1] for L1 or 2nd 2 for L2. Close parenthesis and press ENTER. The L1 list or the L2 list will be sorted.
If the list are linked you must sort them together. In that case the syntax is SortA( L1,L2) ENTER.The list will be sorted according to the order in L1.
Sep 10, 2011 | Texas Instruments TI-83 Plus Calculator
Make a program that will accept tthe size of an array (number must be greater than). Enter and fill the array with numbers then sort in descending order (largest to smallest). Display the unsorted and...
coding in C++
#include<iostream.h>
#include<conio.h>
#define max 50
void main()
clrscr();
int arr[max],size=0;
int i=0,j=0,temp;
do
cout<<"Enter the size of array(less than or equal to 50)";
cin>>size;
} while(size>50);
for(i=0;i<size;i++){
cout<<"Enter a number";
cin>>arr[i];
for( i=1;i<size;i++){
for(j=0;j<size;j++){
if(arr[j+1]>arr[j]){
temp = arr[j];
arr[j] = arr[j+1];
arr[j+1] = temp;
cout<<”Array in descending order”;
cout<<arr[i]<<"\n";
getch();
return 0;
Mar 09, 2010 | Computers & Internet
How to sort the number data in order in L1 for ex L1 -> L1 3 2 2 3 7 4 4 5 5 7 like that thanks
There are two functions available for sorting lists. Access them via [2nd] [List] "OPS".
SortA(list) sorts the list into ascending order.
SortD(list) sorts the list into descending order.
Jan 21, 2010 | Texas Instruments TI-84 Plus Calculator
Doesn't remember there's a Header Row
You can try to select all data (except for the entire row which contain your header) and try to sort thru columns. This can sorted in ascending or descending order.
Jul 17, 2009 | Microsoft EXCEL 2004 for Mac
Autofilter ceases to work on large Excel 2003 spreadsheet
Sounds like there is a gap between the filter heading and the column data. That's the only time I've seen suggested data missing from the drop-down.
Jun 16, 2009 | Microsoft Computers & Internet
May problem is "inputting four numbers and get the minimum number of them, and would be outputting the number in ascending order, BUT skipped the number end in zero and zero number..in javax swing"please...
/* REXX is a better programming language than Java with Swing */
data = '11 10 0 3 12'
filtered = ''
do while (data > ' ')
parse var data value data
if left(reverse(value),1) = '0' | (value % 10 = value / 10) then iterate
if value = 0 then do; say 'Excluding:' value; iterate; end
filtered = filtered value
end
say 'After filtering, numbers are:' filtered
keep = filtered
parse var filtered smallest filtered
do while (filtered > ' ')
parse var filtered value filtered
if value < smallest then smallest = value
end
say 'Smallest value is:' smallest
n = words(keep)
do j = 1 to n
sorted.j = word(keep,j)
end
say 'Smallest to largest:'
do j = 1 to n
do k = (j+1) to n
if sorted.j <= sorted.k then iterate
t = sorted.j
sorted.j = sorted.k
sorted.k = j
end
say j sorted.j
end
say 'Done:'
exit
Access http://www.REXXLA.org to download REXX for your PC (Windows or Linux).
Jan 29, 2009 | Computers & Internet
I have a problem in sorting
If your using windows:
Open cmd.exe (program files>accessories>command prompt)
use the sort command in this syntax:
sort "path name and or file name"
you may also use file exports like this for example:
sort birthdays.txt > sorted birthdays.txt (single forward will write over old files and make new ones)
sort birthdays.txt >> sorted birthdays.txt (use double forwards to made amendments to the file)
the "/R" function will reverse the sort order, for example:
sort /R birthdays.txt
thats all, hope this helps. I cant do much else with the information given.
Jan 26, 2009 | Computers & Internet
What are the source codes for making records in C++?
i need drivers for Sonny VGN-NS150D : WIN XP PROFFENAL SP2
Jan 08, 2009 | Computers & Internet
Sort incoming time for received e-mails
Depending on what client you are using, clicking on the "triangle" in the date column toggles between sorting ascending and descending.
MM85
Jul 22, 2008 | Microsoft Office Outlook 2003 for PC
Video Game Consoles & Games Logo
282 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
