I bought this used and it did come with the software. Any clues on how to get the cd. I have tried the website and get nowhere since it is unavailable.
Hold down the <down arrow> button while plugging in the USB cable and the Treo 15 will automatically start in the Hard Disk mode. Then, you can add or remove software as if it were a hard drive. Works like a charm!! (Be sure to have the power cord attached.)
Was this solution helpful? Show your Appreciation by rating it:
can I add to this answer by pointing out that when the music explorer software has been installed and you do not have the driver for the treo then you can get the treo to be recognised as a HDD ( as d3vil.. mentioned ) by doing the following.....
with music explorer running ,connect the power adapter to the treo device and switch on ; connect the USB plug to the computer and then WHILST HOLDING DOWN the double arrow keys which point downwards, then connect the treo to the pc.... ;
this initiates the treo /pc communication and the treo shows up within music explorer as whichever letter drive in avaliable eg on mine its drive F....then just add/ files as normal
