Water was pooling on the floor after running washer. Took top off and noticed the valve that the hot water runs through was leaking. Where can I find a replacement?
  • blt0215 Nov 11, 2008
    By the way...model is LG Front Load
  • 1,122 Answers
Go to sears .com,click on parts put in your model number and get your part,also cross check the price at repair
Posted on Nov 11, 2008
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
Need to remove and replace electronic water valve
First off unplug washer.
Turn water off hot and cold.
Disconnect water lines from valve.
Remove screws from top panel on washer then slide top panel off.
Remove connections on valve. Make mental note for what goes where. ;)
Remove valve.
Install new valve.
Connect wires.
Put panel back on and screws back in.
Connect water lines hot for hot and cold for cold.
Turn water on and check for leaks around connections.
Plug washer in.
Run a load!
Hope this helps.
Oct 26, 2012 | GE WBVH6240F Front Load Washer
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Water leaking onto the floor
hat leak may not be in the machine. It may be one of the hoses going into it. Look to find out where the water is actually coming from. If it is a hose from the faucet behind the machine, the hose can easily be replaced at a low cost. If it is only leaking with hot water, check the water inlet valve at the rear of machine where the hoses connect, top left rear facing it. If it is leaking and running down the left side, it is the wrong side for the pump unless it running across the floor and out the left side. If it were the hose, it would leak all the time. It sounds like the hot side has gone bad on the inlet valve. You can save several dollars by fixing this yourself.
Tilt it back and look for two screws, near each corner on the bottom front. Remove these screws and pull the bottom toward you. It should lift off the clips on top. Run the machine carefully, moving parts and see if the leak is actually coming from the left rear and from somewhere up high. First try cold water, then hot. If it leaks on one and not the other, then it is the valve. Be sure to unplug the machine if you decide to change this part. Also you might want to mark where the wires go back to be sure you do not reverse the hot and cold water, as well as fittings and connections. The water leakage evidence should be visible. If not, wash a load and watch for where water leakage occurs. Just look. Do not touch since there will be electrical current supplied.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
After instillation, the washer runs several times-then we noticed my hot water heater is shutting the pilot light off. Back pressure possibly on the Hot water side? Was purchased as floor model and N
what kind of water heater do you have?? as far as the washer it has a mxing valve inside the unit that mixes the hot and cold water to get the proper tempreture, write me let me know about the water heatrer,, that is what you are asking about
May 19, 2009 | GE Profile WPRE6100G Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
