Question about Alpine MRP-F250 Car Audio Amplifier
How many speakers can I use?
Right now I only have a 600W Pioneer sub bridged to channels 3 and 4. I wanted to hook up my back speakers to 1 and 2. Can I do this?
    Problem Solver:
  • 5 Answers
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Posted on Dec 06, 2008
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
Looking for info on how to hook up sub to this amp thunder4160
Hi, you have two choices for hooking up a sub to the 4160 amp. You can either connect your sub to one of the two available channels, or if the amp supports it, you can bridge channels 3 and 4 to get increased power to your sub. You have a 4 channel amp - channel 1 and 2 go to your 3-way speakers up front, which leaves channel 3 and 4 available for your sub.
Jul 27, 2013 | Car Audio & Video
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
    depending on how many channels the amp is, you may not be able to hook everything up to it.
    usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
    To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
    If you have a mono amp its only for subs.
    If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
    you need a channel per speaker basically.
    Dec 15, 2009 | Pioneer DEH-P2000 CD Player
    It has an A and B channel for spkrs and i have one spkr bridged. do i split the neg to side a and pos to side b or just use one of the channels?
    Could you elaborate on how the speaker is bridged?
    I think you want to hook up a single speaker to a stereo speaker output.
    In this case, you would strap (bridge?) the right and left speaker terminals by running a short wire from A right negative to A left negative. Then strap A right positive to A left positive -- this will give you mono output on either of the right or left speaker terminals -- connect your speaker to either one of these.
    Do you know what the ohm rating is for the speaker outs on the amp and also the speaker itself?
    Charlie
    Aug 31, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
    What is the best way to connect 4 speakers and a sub to a 4 channel amp.
    I would connect the 4 speakers to channels 1-2 in stereo with high pass filter. Bridge the sub to channels 3-4.
    A thumbs up would be greatly appreciated if this answer is helpful to you. best-way-connect-4-speakers-sub-4-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
    May 01, 2009 | Car Audio & Video
    Troubleshooting amp setup
    You probably need your remote wire re-hooked and make sure the ground wire is good and the remote wire is connected to the right wire(the red wire).
    Jan 05, 2009 | Car Audio & Video
    Hooking up a new 8" woofer speaker to my amplifier
    If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
    • Connect both left door speakers in parallel to Ch A Left.
    • Connect both right door speakers in parallel to Ch A Right.
    • Bridge Ch B and connect it to the new 8" sub.
    • Set the Ch A LPF/HPF to HPF.
    • Set the Ch B LPF/HPF to LPF.
    This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
    Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
    How to
    First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
    Oct 31, 2007 | Pioneer TS-W301R Car Subwoofer
    Speakers
    Hi Trim God,
    I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
    Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
    Alpine MRP-F250 Car Audio Amplifier Logo
    141 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
