Question about Apple PowerBook G4 Mac Notebook
Powerbook G4 Titanium..sticking on any movement
Mac Powerbook G4 Titanium Laptop..drive seems fine..startup hangs up alot..movement if it does start up hangs up.  Info leads to resetting ram chips..have not done that yet..otherwise a display problem or cable inside the laptop to display..may need parts.   Is it worth trying to fix it to keep it for a surfing laptop machine? Any idea on parts...I do have a local Mac person for $80 per hour..but, suggests it is display & cable issue..need to find parts.
  • JDTec
    JDTec May 11, 2010
    This is usually a loose or intermittant ram module. Also, has this unit been taken apart recently? If so, a connection on the main board was probably not made correctly.
  • 4 Answers
1. Go to Support on Apple.com, search memory upgrades for your model and follow instructions for inserting the ram modules correctly. These MUST be properly seated and locked or strange intermittent bad stuff will happen.
2. At same time note make and type of memory from label, and double check that it is the correct memory from a high end maker. Macs do not like low-life sketchy memory.
3. Cables that go through the hinges are very fragile and subject to damage as well as wear and tear. Limit opening and closing display, partial or full. Titanium's have well-known hinge problems - do not let them get loose, and Google solutions if they do.
4. Find a nearby Apple store and make an appointment at the Genius Bar. It won't cost anything for a simple diagnosis or repair, and they are VERY helpful as long as you are too.
5. Parts: iFixit.com, and Google many others some with specific repair instructions on-line. I have a spare near new display cable for Titanium's, but replacing this part is extremely difficult for even most experts.
Posted on Nov 18, 2008
Where are the printer inputs for a titanium mac?
USB and RJ45 ports are located on the site of the laptop, usually on the right-hand-side for PowerBooks.
Feb 16, 2013 | Apple PowerBook G4 Mac Notebook
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
HELLO
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA https://plus.google.com/u/1/116937682228750782866 APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Mac G4 Running Slow
Many many reasons may be causing your Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more from: http://www.howtospeedupmac.com/
Jul 22, 2010 | Apple Powerbook G4 15" Screen Mac...
My dvd rom on my mac g4 powerbook won't read my disks, I insert it then it spits it back out.
Try different DVDs and then try different CDs. If it spits out all of them, then its time for a new optical drive.
Jan 22, 2010 | FastMac (APP-5693) for PowerBook G4...
Powerbook G4 blue screen on start up
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Regards
nicole
Oct 03, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook G4 titanium
Insert your Mac OS disc, restart your computer while holding down the C key. This will launch your computer on the disc system instead of your hard drive.
From the menu select Disk Utilities.
Repair permissions and repair hard drive in your computer..
Restart... you should be back up and running.
K
Jun 21, 2009 | Apple iBook G4 Mac Notebook
Apple Titanium Laptop
This happens, and unless your startup disk is locked up and needs some swap space, it's just a matter of a screen whose time has come.
Apr 29, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Mac Powerbook Software Issues
Hi-
chances are you are having a Corrupt OS, you can actually try to trash and reinstall the softwares that is corrupted or update OS to either 10.4 or 10.5... Hope this helps.
Jun 11, 2008 | Apple PowerBook G4 Mac Notebook
Apple PowerBook G4 Mac Notebook Logo
85 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
