Question about Toshiba Satellite A205-S4617 Notebook
Won't start I have my power cord plugged into my computer but it won't start when I press the start button. A small message box came up and said" consult manual" My manual doesn't have anything like this in it.
  • 685 Answers
Check your power supply
Posted on Nov 11, 2008
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Sep 28, 2012 | Washing Machines
My emachine won't power up.
Power is not working.replace the power cord and check if it stays the same then your power box is not working.
Jul 16, 2012 | E-Machines eMachines Desktop PC
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
X5470 constantly is powering on and off
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Nov 02, 2011 | Lexmark X5470 All-In-One InkJet Printer
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Toshiba Satellite A205-S4617 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
