DONT TURN ON & OFF
HELLO!! I HAVE A OLEVIA 23" HD TV BUT IT DON'T TURN ON &OFF ONLY BE STANDBY , WHAT I NEED TO CHECK OR REPLACE THANKS
  • 685 Answers
It would be best to just replace it
Posted on Nov 11, 2008
Tv won't turn on no blue light either
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Olevia LT23HVX 23 in. LCD Television
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia 537H power button stays on tv randomly turns on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Mar 30, 2012 | Syntax Olevia 537H Television
My Olevia TV turns off on its own when I turn it on after 10pm...please help!
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 18, 2010 | Olevia LT23HVX 23 in. LCD Television
I have 19" Olevia LCD TV and the red power light comes on when you plugged it in but the TV DOES NOT power on
You only have 5v standby voltage circuit working. The problem can be i nte main power supply or the main control board that send the signal to the main power supply to turn on. Those are the two place to look for.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Won't always turn on
These olevia tv's were only made to last a few years. the company has gone out of business. they took the money and ran.i also have the same exact problem. the power supply board needs replacing and i can't find one. repair shops want almost 300 to fix but it isn't worth it. thow away or if your lucky enough to find a power board fix it yourself for around 100. i t k mine apart seems easy to fix.
May 26, 2009 | Olevia LT23HVX 23 in. LCD Television
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Olevia - hidden mini HD service input
I have pictures of the USB port, as well as the procedure of what I did, once the USB trick quit working here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/
Jul 23, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia won't turn on.
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
Mar 04, 2008 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
