Question about Pioneer SD-532HD5 53" Rear Projection Television
Removing the protective screen on our Pioneer SD-532HD5
We've had our Pioneer for sometime and we need to clean behind the protective screen. Does anyone know how to take it off?
Pop the bottom front cover off (that is over the speakers) first. This will expose 2 brackets that hold the moulding around the screen in place. Un-screw the brackets enough so you can get the moulding off and take it off. Once the moulding off you will see the brackets that hold the actual screen in place. Loosen these brackets and VERY carefully remove the screen (it will wobble and bend so I would recommend 2 people do this). Lay the screen down on a soft surface that will not scratch it. Clean and re-install screen, tighten brackets, re-install moulding, tighten brackets and pop the speaker cover back on.
Posted on Feb 25, 2009
Vga hook up
may need to tell the laptop in the screen resolution settings to display the image on the tv instead of the laptop. Right click on the empty desktop of the laptop and go to either propertie or screen resolution and then make sure that the computer can see that the tv is hooked up and that the image is showing on the tv instead of the laptop. You may also need to change the mode on the tv to vga.
Nov 21, 2013 | Pioneer SD-532HD5 53" Rear Projection...
My wife was cleaning around our Pioneer sd-532hd5 tv and she moved the tv to clean behind it. When the did, the color went awry. The sound and video is ok, just the color was affected. We have checked the...
now in the front of your tv you will see a weird piece of wood that looks like it doesent belong now its a piece of wood in the front of your tv sicured by a few screws and 2 dowels and inside you will see 2 circut bourds infront of you and a few more behind them , you will also see some connections to the botom of the projectors themselves , now you need to look to your left side and on your left you will see a little black or white casing with what looks to be 6 screws on it , but there not screws there the adjustments for your tv now just fiddle with those 6 screws til you can find your favorite color or setting and close it back up and ENJOY!!!!
Jan 18, 2011 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Manual for Pioneers Flat Screen TV
Contact me I can get you a copy of manual for $25.00 Camale001@hotmail.com
Dec 15, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Off Screen Picture
There is a width problem. There could be a control inside to control this but the TV should not change so drastically. There is most likely a problem in the width circuit.. This is a high voltage circuit, and is very dangerous to tinker or experiment around inside of. Your best bet would be to call an Authorized Pioneer repair shop and have them have a look at the set. Good Luck
Jul 14, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Possesed awesome tv
the clicking noise is probably just the relay. I gyess it makes the same noise if ou turn it off manually with the remote? Does your TV have a sleep timer function? Check to see if this is enabled. You might also check the batteries. If they are old, or the battery compartment is dirty (leaking barteries etc) you might get strange behaviour. My remote lives a life of it's own, changes channels etc if the batteries are weak.
May 17, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5
it is time to buy a new one,,,sorry
Aug 23, 2006 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
294 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
