Question about Contax 167 MT 35mm SLR Camera
Overexposed highlights Hi, I have recently bought a used contax 167mt and notice that in the pictures the highlights are bit overexposed, i am guessing this might be because the camera has been used a lot and its passed shutter life...but i would like to know what really the problem is. Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Contax Master
  • 102,366 Answers
Normally the problem is simply that the pictures are slightly overexposed. Despite all the fancy names manufacturers stick on their metering systems, the camera doesn't know what you're taking a picture of. They basically strive to make the entire scene a medium gray. As a result, some highlights may be blown out, just as some shadows may drop out. Generally, dropped shadows are more acceptable than blown highlights.
If a picture is really important, bracket. Take one shot at the metered exposure, then another a stop under (and perhaps one a stop over, if you're feeling paranoid). It was common for a National Geographic photographer to spend an entire roll on one shot, trying different light angles and exposures. After all, film is far cheaper than air fare and hotel rooms.
One advantage of shooting digital is that you can see the results immediately, and correct for blown out highlights.
Posted on Jan 16, 2010
Camera makes overexposed pictures wiht lines can this be a software problem ?
Nope, this is a hardware problem and the camera needs to be worked on. Notice how your display works fine but the finished product exhibits the anomaly. The recording end is messed up.
Aug 12, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
No power to contax 167mt even with new batteries
Do not use rechargeable batteries.
All batteries much be brand new. Some new batteries may have been sitting around for years can become defective.
May 17, 2012 | Contax 167 MT 35mm SLR Camera
Re. Contax 167MT problem -- When the depth of field button is pressed the lens does not close down to the set aperture. Also when the shutter release button is pressed the lens does not close down. My two...
The 80s 167MT uses good old fashioned mechanical links between the camera body and lens. Remove the lens, and press the depth of field button. If you don't see the lever that connects the aperture control from in the camera body to the lens move, then something's obviouly broken in the camera body.
Nov 11, 2017 | Contax 167 MT 35mm SLR Camera
We have a canon powershot A410 digital camera with 3.2 mega pixels (purchased brand new in fall 2007) and recently, whenever we take pictures outside, they come out completely white (overexposed). The...
Hi there its a chance of sersor damaged. He not able to read the light. Thats why outside image are over exposed. I suggest you visit service center for check or repair the lens sensor.Thanks.
Apr 07, 2010 | Canon PowerShot A410 Digital Camera
When I try to view my pictures on the LCD screen, the white area of the picture flashes. Last week on vacation, it would intermitenly stop taking pictures. I would have to set the lens and camera to...
If this is the same as my Nikon this is the overexposed highlight display option.
This shows areas of the photograph that are overexposed slightly.
On my Nikon I use the up and down arrows on the back to cycle the LCD display options.
Stop when you get a display that does not flash.
As for the focus problem check if you have set the front control to AF not M, also check if the lens is set to A not M.
Jul 06, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blinking black in play mode!!!! PLEASEEEEE HELLLPP
Jul 06, 2009 | Nikon D40 Digital Camera
When viewing pictures on camera why are the white areas of pictures blinking
Jun 30, 2009 | Nikon D40x Digital Camera
Outlines/highlights appear on the lcd screen after taking a photo.
hi
just press the down arrow on the navigation button after taking a picture . what happened is the viewing mode was accidentally set to automatically highlight the overexposed areas.
Oct 14, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Contax 167 MT 35mm SLR Camera Logo
142 people viewed this question
Top Contax Photography Experts
Electric Dime
Electric Dime
bayou sam
Are you a Contax Photography Expert? Answer questions, earn points and help others
